D17 power steering line needed
ironac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ironac Quote  Post ReplyReply Direct Link To This Post Topic: D17 power steering line needed
    Posted: 25 Mar 2012 at 4:40pm
Working on a FFA project and need a discharge tube/line for a earlier d17. Thanks
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2012 at 7:46pm
   TELL ME A PART #   WERE 3 DIFFERENT POWER STEERING PUMPS USED     EVERTHING WOULD BE A GUESS   1-574-342-4545 FOR INFO.
Unstylish View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unstylish Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2012 at 7:59pm
Call me 269 921 4686. If its ffa, you can have it, if I have it. Andrew
Post Options Post Options   Thanks (0) Thanks(0)   Quote ironac Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2012 at 9:45pm
I will find the part number and give you a call when I get the number. It's a 1959 d17 gas that is going to the Iowa state fair. Thanks
pied View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pied Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 2:18pm
     Did you rebuild the power steering front support? If so how difficult was it? I'm having problems with my D17 Series IV. Seems something let go in the front support and I was wondering what I'm about to get myself into.Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote ironac Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 2:24pm
The ram rack was broke on it so that was replaced. I thInk the powersteering setup on a series 3 and 4 are differnt from the earlier 1 and 2
pied View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pied Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 2:33pm
  Was it a very complicated task? How hard was it to find the correct replacement parts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 7:43pm
  HAVE REPAIRED BEFORE  MAY JUST HAVE THE PIN SHEARED  HAVE THE PIN IN STOCK
   GOOD PROJECT   WAS DONE ON TRACTOR
pied View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pied Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 9:33pm
   Will I have to drop the whole front support to check if its the pin?Ouch
OrangePowerFranzen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangePowerFranzen Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 10:30pm
ive been working on this d17 with ironac, and this is what we had to do for drop that front powersteering gear and rack. we r looking for the largest tube that runs from under the front of the left side of the engine , runs to the right side and up to the powersteering, its the largest of the 3 tubes that are present.
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2012 at 10:22am
I would have the line. Need to know which one. 785-353-2392
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2012 at 11:01am
you say you need the discharge line? which is part #70229825 for a gas tractor
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2012 at 11:24am
how the heck do you break that?
Charlie
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2012 at 4:01pm
I had to replace the seal on the main steering shaft.  The hardest part for me was moving the front wheel assembly out from under the tractor.  Two people really helps.  The bolster is heavy but take out four bolts and support it with a block and jack and you are good to go.
1944 Allis C
1960 Allis D-17 LP
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangePowerFranzen Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2012 at 5:24pm
i will look up that part number tonight, i beleive that the fluid had water in it and froze up and thats how that ram rack broke, it surprised both of us to
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangePowerFranzen Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2012 at 11:21pm
still looking for the power steering line, does anyone know of the allis chalmers salvage yard located by anamosa, iowa? ive seen it in a tractor house book and was wondering if anyone knew of the guy that runs the place
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2012 at 11:12am
I am shure I have what you need. Will  need no , picture ,some thing.785-353-2392
