WD-45 3 point conversion plowing
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Topic: WD-45 3 point conversion plowing
    Posted: 17 Mar 2012 at 7:50pm
Anyone out there using a WD-45 with a 3 point conversion for plowing. Does it even work? anyone have any photo's?
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 8:03pm
yes, yes, and no i don't, but with a set of wheel weights and loaded tires I can run a 3-14 just fine
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 8:12pm
I have converted my 45 over to 3point using the pieces from a David Brown and have a nice AC 16'' 3  bottom plow. I was hoping this set up would work as good as the old snap coupler.
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 8:51pm
not sure how it will do on a 3-16 without being able to utilize Traction Booster. best thing to do is get a 3pt S/C adapter, then you can still use the traction booster.
German Shepherd dad
#WD234847
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 8:53pm
one idea I had was to take the two point arms, and fab somthing so they attach to the snap coupler bar. if I do it, I'll let you know how it works
German Shepherd dad
#WD234847
#WD88193
This page was generated in 0.071 seconds.
