6 volt to 12 volt "CA" conversion
JarrodACFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JarrodACFan Quote  Post ReplyReply Direct Link To This Post Topic: 6 volt to 12 volt "CA" conversion
    Posted: 17 Mar 2012 at 7:23am
what all has to be changed to change My CA from 6 volt to 12 volt, I know the obvious to change bulbs and battery.
I don't think the starter has to be changed. and I would need to replace the generator with a self regulating alternator.
Anything else or things to watch for.
thanks, Jarrod
1956 WD45 Narrow Front Factory Power Steering, 1953 WD Wide Front
Allis Express in Muncie, IN
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 7:26am
You will need a resistor for the coil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 8:09am
I wouldn't mess with buying a resistor for an antique coil. Buy a new 3 ohm coil and be done with it. The other thing you will need is a diode in line with the alternator or you may have trouble shutting the engine off. Switch to neg ground and reverse the wires on the coil.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 10:59am
Need to swap the wires on the ammeter too and for the alternator probably put in a 50 or 60 amp ammeter in place of the original 20 or 30 amp.
It is possible to rewind the generator for 12 volts or to find a 12 volt generator or to just turn the 6 volt one faster, but that means it may not charge at slow engine speeds where the alternator will do very well. You'd need a 12 volt regulator for the modified or sped up generator and it has to match the field circuit if you get another from a car or truck.
Gerald J.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 2:53pm
Check out Duey's page. Really helpful infohttp://dueyschutter.freeservers.com/photo3.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 3:26pm
Originally posted by Gerald J. Gerald J. wrote:
Need to swap the wires on the ammeter too and for the alternator probably put in a 50 or 60 amp ammeter in place of the original 20 or 30 amp.Gerald J.
  Maybe I'll do that to my 45 when I get rountu replacing the key switch. Mine has been swinging to the right when I turn the lights on and to the left when the tractor is running. doesn't hurt anything as long as the operator knows about it.Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 6:18pm
Ammeter backwards will work fine forever but confuse the inexperienced operator.
Gerald J.
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 8:37pm
 Why would you want to? If you fix the problem you won't have to change wiring, battery, coil, lights, gauges & generator.
 Would it not be easier just to fix the starter and use the right size battery cables? 6 volt battery turns my "CA" over with ease.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote JarrodACFan Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 8:51pm
I am still undecided on whether to switch it to 12 volt. If the generator is bad, I will go ahead and switch it over.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 10:15pm
We offer a complete 6V-12V conversion for the B,C,CA Tractors. Gives you everything needed to do a pro wiring job. Complete with step by step instructions also. If interested, drop us a line at customcircuits@gmail.com  Be happy to help you out. This one happens to be for the WD/WD45, but the B,C,CA version is very similar... Steve@B&B
