d17 hydralics
Thumper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thumper Quote  Post ReplyReply Direct Link To This Post Topic: d17 hydralics
    Posted: 16 Mar 2012 at 4:31pm
I'm having trouble keeping a  seal in the distributer side of power steering.One suggestion was to check for shaft play,I've done that and find none.Any other ideas?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 6:28pm
The pump is probably worn out.......new needle bearings and new seals at a minimum. Also don't use Dexron, use modern day universal hydraulic fluid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thumper Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 6:57pm
My manual is well detailed..do you think a country boy can do this?
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 7:22pm
YES :)
Still in use:
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 9:13pm
Probably a darn sight better than a city slicker could!  A man made it, a man can fix it...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thumper Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 4:14pm
Thanks guys,well get ER done
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 10:34pm
It was MADE by country boys... FOR country boys-  I'd sure-as-heck think so!!!
Other reasons why hydraulic system blow seals and puke... the ventilation device isn't working, or the system is overfilled, or the pump is sucking in air and aerating the fluid... which also causes the fluid to overheat, and the pump to howl.
donais View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote donais Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2012 at 9:35am
my pump d17s3 had a blowing seal problem ended up changing the bearings and had to add a speedi sleeve to the seal surface to cure its problems not hard to do..and so far it has worked
