Power steering seal
Thumper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thumper Quote  Post ReplyReply Direct Link To This Post Topic: Power steering seal
    Posted: 15 Mar 2012 at 8:41am
Neil,You talked about shaft play,was this with all gears in tact? I pulled my distributer,and with access through the rear housing,I can't wiggle or move the shaft at all.Would you reccomend tearing the assembly down and replacing all bearings you mentioned? I have no idea how many hours or service history on the tractor,I've replaced most of the gauges so I can moniter operation!
