D-17
blacksmith67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blacksmith67 Quote  Post ReplyReply Direct Link To This Post Topic: D-17
    Posted: 14 Mar 2012 at 10:40am
I have a D17 that has no oil pressure. It  easier remove the engine or to take the pan
off to get at the oil pump?  Any help or suggestions would be helpful.   Jim
Seth Souerdike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Seth Souerdike Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 11:30am
met a guy once who said its easier to take the pan off to get to the pump but he did that for a living for 30 years.
There are no atheist in foxholes.
D17countryboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17countryboy Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 12:45pm
It should be easier to drop the oil pan to get to the oil pump rather than removing the engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 1:47pm
Tell me how you get an oil pump out of a D17 (assuming it is a 226 gas engine) WITHOUT taking the oil pan off, regardless if the engine is still in the tractor or removed?  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 2:59pm
I THINK what he means is will the pan come off with the engine still in the tractorThumbs Down
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 3:18pm
Shop manual says the front pedestal has to come off to get the pan off. At that point, I'd say pull the engine.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 3:52pm
As I recall, my manual doesn't say the pedestal has to come off.
pirlbeck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pirlbeck Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 4:27pm
If the tractor is a gas and has power steering the right hand side rail of the pan is above the steering ram. From the factory AC had a one allen head screw that came in from the top for the one cap screw that is completely hidden by the steering cylinder. Even if it has the allen screw, the lip of the pan is hard to get out from above the cylinder. Also, if it has ever been apart, it may of been changed over to a regular cap screw inserted from the bottom. I was taught by a long time AC mechanic that it is easier/faster just to pull the front end to remove the pan.
If the tractor is a diesel, the above may not apply, don't know if I ever worked on a diesel.
Edited by pirlbeck - 14 Mar 2012 at 4:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 4:48pm
The front of the diesel oil pan seals to a plate sandwitched between the block and timing cover. That plate is the front engine mount. I can't say for 100% that it has to come out, but I can't imagine it would be very easy to get the pan out with that plate in place. Forgot about the P/S steering cyl being in the way...
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 5:11pm
Yep...that's the reason it's easier to slide the front pedistal back to get the oil pan off...the power steering ram/cylinder is in the way. If it don't have power steering,then the oil pan comes off easily.  Rick
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 6:50am
I think before going to all that work, and it is work, because you will have to take the front end off.  If it is a series I, pull the pressure regulator spring, and start it up for a second, see if you get oil, if you do it will be a lot, so be prepared.  It is possible the pump is working, and you have a blockage somewhere after the pump, before the gauge.  IF you have no oil coming out, I would then prime the pump, just in case, but forcing 30 weight oil in the open hole, let it sit for a few minutes and then fire it up, for a second.  See what happens.  All of this said, the important thing is not to run it for more that a couple seconds each time, this will help you know what's going on, and could possible save you a lot of work.  If it is a series II or newer, just open the lines at the bottom center of the block, and try the same thing.
Still in use:
roscoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roscoe Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 7:08am
I just happend to have my service manual open to that section, because I need to replace the governor weights and gear. (different story)
Anyway, the service manual says:
