Need Help D10 sterring box!!
Jamie NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamie NC Quote  Post ReplyReply Direct Link To This Post Topic: Need Help D10 sterring box!!
    Posted: 13 Mar 2012 at 9:32pm
I need the part number for the bearings on the worn gear shaft .
Jamie
Thanks
Allis tractor puller CA WC WD D17
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 2:33pm
I think the bearings are the "open race" type. I have used the balls from a sealed 6205 bearing (avail at your auto store or snowmobile dealer). Do not have a source for the races (am not located near any real good bearing house); and have had to reuse the ones in the box. I have found that placing the lower race in the upper position and lower race in the lower position works better (the lower race generally has more pitting/corrosion than the upper race.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 3:48pm
Did you mean to say "UPPER race in the lower position"
in other words switching locations with the two existing bearings.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamie NC Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 10:41pm
thanks for the info guys
