G Fan shaft Bearing Removal
Allis Barn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Barn Quote  Post ReplyReply Direct Link To This Post Topic: G Fan shaft Bearing Removal
    Posted: 12 Mar 2012 at 4:57pm
I have read the Service Manual on remving the fan and the pulley so that the two bearings can be removed.  But that does not seem to work.  both the fan and the pulley are too light weight stand  up to a gear puller.
Any suggestions?  Need to replace both bearing .
thanks
Bob
Warren(Oh) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warren(Oh) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2012 at 5:08pm
They have to be pressed off and on. I didn't get to watch when mine were removed last year. NAPA shop did mine.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2012 at 11:25pm
you need a "split bearing puller attachment". It clamps on behind the pulley and you attach your puller to it so the pulley is not damaged. I applies even pressure all around the circumference. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Barn Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2012 at 9:50pm
Thanks Warren and Bob.  Had to use the advise of each.  Pulley end bearing and pulley came off with a gear puller and split bearing puller.   Had to have a press for the fan and the fan end bearing.  Took ten tons of pressure and the fan hub heated cherry hot.
However the new bearings sure do reduce the engine nosie level.
Thanks
Bob @ Allis Barn
PS Know of anyone having a used G hood for sale.  Mine has been cut and modified
