d-19 belt pully??
cornbinder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cornbinder Quote  Post ReplyReply Direct Link To This Post Topic: d-19 belt pully??
    Posted: 10 Mar 2012 at 6:24am
was a belt pulley an option on a d-19? if not not will a pulley set up off of a d-17 fit on a 19? just curious
Bolivar Boy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bolivar Boy Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2012 at 6:45am
corn binder boy. nie states we need a long tube pulley off another 19 or a 190. i've never even seen a 190 with a belt pulley !
nevans View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nevans Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2012 at 7:59am
We have a belt pully for a 190 and also one for a D14 15 Niel
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2012 at 9:32am
Where is the 'live hydraulic pump' located on a D-19 ?
Gary
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2012 at 10:15am
Gary
There isn't one unless somebody has installed an aftermarket pump that, for example, may be driven off the front of the crankshaft.  D19 is set up just like early (pre Series IV) D17.  The hydraulic pump quits if the foot clutch is disengaged, but continues to run if tractor is stopped with the power director.  I guess technically this would be live hydraulics, but not "independent"...kind of the same terms used for the PTO.  People tend to argue all day about the definitions of "live" and "independent".  We all know how the older AC's are set up and it never seemed to bother me that everything stopped when using the foot clutch.  I actually kind of like it that way..especially for the PTO.
Edited by DanD - 10 Mar 2012 at 10:20am
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2012 at 1:32pm
Mine has one and it looks like the same thing as a D17, This picture is a little old, she's 14 now and the dog has passed.
AGCO My Allis Gleaner Company
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2012 at 3:54pm
D17 should be the same.
DarrylinWA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DarrylinWA Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2012 at 8:39pm
I would like to find one for my new D 19 Diesel. It has every option on it now except a belt pully. Should it  "Bolt right in " or is there much else it needs to make something like this work ?
Thanks Darryl
B 10 Custom. Serial # 1001 D21, First D21 built 69 #4498 and Last D 21 Built #4609. 1946 MM UTU. And 2000, 2005 Pete's. AC custom Hauling.
Luke R. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luke R. Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2012 at 8:57pm
It should bolt right in Darryl. But i think you have to meaure for shims. I could be wrong though. Ive only had two 19's with belt pulleys.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2012 at 8:49am
Saw a 190 with a belt pulley powering a sawmill at a threshing show once.  I think it was Cedar Falls, Iowa. many years ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2012 at 8:54am
Mine has the rod setup on it to engage/disengage it, but the pulley is no longer on it.   Would like to find one someday to add to it.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2012 at 1:47pm
Shims are required, unless you never plan to use it, maybe just for show.  If you do put it on without shims, make sure you have at least some lash, or you will burn up the shaft where the gear rides.
Still in use:
This page was generated in 0.219 seconds.
