wd45 steering knuckle repair
Mike56073 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike56073 Quote  Post ReplyReply Direct Link To This Post Topic: wd45 steering knuckle repair
    Posted: 08 Mar 2012 at 6:21pm
    Does anybody have a part # for a u-joint kit for the steering shaft?  By the way it looks there has to be a small one that should match up..........
AC-Farms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC-Farms Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2012 at 7:37pm
I've used case-ih part #84355036 from the local dealer.  The last one I bought had a zerk in one of the caps, I think it will clear everything ok, if not just have to screw the zerk out and put a plug in.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2012 at 9:37am
I got the last kit from NAPA back in 2001.
Their "precision" kit was part #861. It has a grease fitting and the bearing journals and bearings are longer than original but still clear everything fine. It was only $7.99 at that time!
I have cross referenced it to:
A-C #2248900
NEAPCO #1-1475
TRW #20001
