WD Brake Question, Diff. Seal #'s
Mike56073 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike56073 Quote  Post ReplyReply Direct Link To This Post Topic: WD Brake Question, Diff. Seal #'s
    Posted: 07 Mar 2012 at 8:55pm
    Hey guys,
On a WD, I've got the brakes out, and the linings are about 1/4" thick.  How thick are new linings?  I also have one brake drum with 1/8th inch deep grooves in it, does it need replacement ?
  Second question: Does anybody have seal numbers for the differential ? I'm talking about the 2 seals that go into the end caps on either side of the diff.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2012 at 7:33am
I would replace the linings while they are out. The drum should be ok if the major OD is ok.   MACK
RickinNH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RickinNH Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2012 at 8:04am
The new pads i have came from Valubilt and are less than a 1/4 thick new. .223 thick. If the pads are not scored like the drum give some thought to not replacing them. The new rivet installation takes some time to develop a method of doing. Search some older posts before you make up your mind.
