fixing up my wd disc
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Topic: fixing up my wd disc
    Posted: 06 Mar 2012 at 2:16pm
Lifted my disc up to start repairs. Has a few broken blades and spacers. One gang down, one to go. I need to find the tees that go on the lift chains still and tighten up the Frame. This is a big step up from the old light weight farmall disc I had before.
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 3:20pm
Is that a CA 20 disc? With the small threaded rod up front in the middle to adjust the fore/aft pitch?
If so, it will be good for spring work but may be too light for fall tillage in cornstalks (bean stubble might be OK).
HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 3:39pm
Its a wd 20 disc. A little over eight foot wide. I only grow veggies and it is much heavier than my old one. Mostly it will be nice to be able to lift it and move it around easier. Nice to have all orange equipment now too.
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 4:35pm
Glock I use 7/16 bolts with a chain coupler on rach end of chain, I'll try n get pic instead of words.
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 4:39pm
Glock on the right lift arm if you zoom in you can see the repair link and through the top of it I have a 7/16 bolt with washers and a locknut. Works great.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 5:35pm
That's how I got mine set up right now. Seems to work ok on the wd but pops out of the ca though. That's a nice looking disc. Wish mine was that nice!
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 6:36pm
Hey, if you don't have to mess with the bearings at all, your already ahead in the ballgame! Have a #40 that needs bearings.
Galatians 5:22-24
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 6:42pm
Glock I had a friend make decals for the back after this pic. Allis Chalmers 20 Series. These discs were in good shape when I bought them except the blades were worn thin and hitting rocks would split them. All new 20" cutter discs increased the weight dramatically! You sure don't want to be discing up a hill and lift them with the way my WD is set up!
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 7:11pm
Glockhead, looking at your engine hoist, you really are a shadetree mechanic, aren't you??
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 10:22pm
I still have some used bearing. Maybe a few other disc parts. 785-353-2392
