serial no.
johnnyjr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote johnnyjr Quote  Post ReplyReply Direct Link To This Post Topic: serial no.
    Posted: 05 Mar 2012 at 8:15pm
hello to all.where can i find the serial no. on a 39 B ?  I have oil pressure problems with the oil pump. didnt get started on it yet, but looking for some info. thank you, john
nevans View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nevans Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2012 at 8:17pm
Its right by the shift lever stamped in the housing niel
Post Options Post Options   Thanks (0) Thanks(0)   Quote johnnyjr Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2012 at 8:20pm
thank you neil, i will look tomorrow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2012 at 8:20pm
Some of these old things can take a prime to make them work, if it sat around for a long time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote johnnyjr Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2012 at 8:25pm
yes i agree however i pressurized the oil line with oil ad still have only 1-2 lbs pressure.  im assuming the problem is the pump  john
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2012 at 8:48pm
Don't jump to conclusions too fast.  It could be the tube inside the oil filter is plugged or broken or a bad oil filter.  Try the easy, little things first.  Clean the oil lines and try a gauge that you know works.
