CA Hand Clutch
Reed(UT) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reed(UT) Quote  Post ReplyReply Direct Link To This Post Topic: CA Hand Clutch
    Posted: 05 Mar 2012 at 3:03pm
I looked at a CA over the weekend, and the hand clutch appears to be welded together.
Is it a major job to replace/repair this?
The tractor needs brakes too -- how big of a job is that?
Thanks!!
2 WD45s, 190XT III, 72 AllCrop, Bunch of snap-coupler stuff. Looking for a B and CA
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2012 at 3:38pm
hand clutch isn't to bad. pull the final drive and beat, cuss and bleed depending on how rusted together it is.
Brakes are easy if it just needs new bands. If the drums are shot your pulling the final drives off.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2012 at 3:58pm
Reed
If your hand clutch has been welded together you may need to obtain another from a donor tractor. Rebuilding the clutch is not difficult at all, if you have a decent clutch to begin with, and the linings, springs, etc are available.
You can replace the brake bands without removing the finals; just be sure your brake drums are still good 1st. You need to pull the finals to replace the clutch and brake drum on the non clutch side. The brake drum on the clutch side is integral with the clutch pack, it is keyed to the outer pinion shaft and may, or may not be easily removed from the shaft. The brake drum on the non clutch side is also keyed onto the outer pinion shaft and most likely will be difficult to remove. New brake drums for the non clutch side are readily available, the brake drum for the clutch side is VERY expensive (I have found it cheaper to have the machine shop turn down the drum, machine a tight fit cylinder to fit over the turned down drum, and spot weld it in place).
I have a pdf file available on rebuilding the hand clutch should you decide to go that route.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reed(UT) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2012 at 3:58pm
Thanks for the reply.
How much dinero will i be for a new hand-clutch and brakes?
**posted before I saw your reply Greg!**
Does anyone have a donor clutch they could part with?
Trying to get my ducks in a row before jumping in... This would probably be the first time for me!!
Edited by Reed(UT) - 05 Mar 2012 at 4:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2012 at 7:26pm
Reed
Found these brake bands on eBay, the vendors here can probably beat the prices (and they are great folks to work with). Try advertising on the classifieds for a handclutch assembly to find out what they cost. Should you pull the finals, recommend you also purchase a pair of inner pinion shaft seals (from AGCO; not the equivalent aftermarket ones) and install before re-installing the finals.
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 12:18am
If you don't think the  hand clutch is going to be a usefull option in the CAs future you can swap it out fairly cheap with a straight axle like the one on the left side. You will need to find somebody who is parting out or parts out CAs for a straight axle. You will need a brake drum too.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 4:29am
I have the drum/parts available for the hand clutch assy. Can supply new linings for hand clutch with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 5:39am
Reed
Have purchased the clutch friction material from Chris in the past; much better quality than what is available from AGCO (and the cost is comparable). The springs are available from AGCO. You may be able to salvage your clutch depending on how it was welded and if the ears holding it together are not broken.
bently View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bently Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 7:29am
Chris, do you have the right side drums for a ca? I'm just finishing up rebuilding mine and Greg is right, the clutch side drum is spendy. I didn't have any choice, the drum was shot, but I'm thinking about picking up another ca so it would be good to have another source for next time just in case. Thanks.
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 9:35am
Reed  - You asked about cost.  My clutch was also welded together.  I completely rebuilt my clutch - new linings, springs, balls, 3 new ball seats, bushing, resurface plates, resleeved brake drum and new brake linings.  Did work myself - approx $400
