Quick Question about Carb on G
John Kenny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Kenny Quote  Post ReplyReply Direct Link To This Post Topic: Quick Question about Carb on G
    Posted: 29 Feb 2012 at 2:30pm
Quick Question about a G carb... When putting in the new gasket for the carb does the venturi sit ABOVE the gasket or does it wedge in it with the thinner upper part sticking up and the lower part sitting below the gasket?  Also, does the float pin assembly also sit above the gasket in that little notch while the float itself sits below?  thanks, the manual is a little confusing.  John
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 11:03pm
you have to install the venturi before the gasket and the float after the gasket.
At least that is how I did mine. Bob
