How do I get this bearing out?
outlook6 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote outlook6 Quote  Post ReplyReply Direct Link To This Post Topic: How do I get this bearing out?
    Posted: 27 Feb 2012 at 7:23pm
Any suggestions on how to remove this roller bearing in the PTO housing on my B model?  There's no way to get to it from the other side to drive it out and what ever puller it takes I don't have.  It's the bearing that the end of the transmission main shaft fits into.  I have removed the snap ring.
As always, any help is greatly appreciated.
Jim
Pat T View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat T Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 7:35pm
Jim
If you have a small two jaw bearing puller you could try reversing the jaws so that the claws are facing outward from each other, then place a good piece of flat steel (like a good sized crescent wrench laying flat) diagonally across the casting to provide a point for the puller's center screw to push on while the jaws are hopefully hooked into the inside of the bearing race.  Just a suggestion.  It looks like once you get this coming out it will not take too much force as long as it is being lifted evenly.
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 7:40pm
knocker puller
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 7:56pm
Providing you are not going to reuse the bearing... Cut the roller cage and take out cage and rollers.  Then weld a bead around the inside the outer race (taking care not get any weld out side the bearing race and not burn through) let cool completely and remove with fingers.  The weld will shrink the race making it easily removed.   Tim
JW100007 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW100007 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 8:16pm
I have had many successes by welding a nut over the
inside  race, Then. take a full thread bolt or a piece of
all-thread and screw it into the nut.  This will jack the
old bearing out.          John
dad2many View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dad2many Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 8:36pm
Since it doesn't have an inner race, cut the cage and remove the rollers. Welding the race half way works good. Your local auto store should have a loaner internal puller. You can also use the hydraulic method after removing the rollers, find round stock to fit bore. Fill back cavity with heavy weight lube and drive the stock down. Fluid will force the race out.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 8:46pm
slide hammer with internal jaws, like removing a pilot bearing from a flywheel
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 9:08pm
  we have a brg. on our desk     1-800-254-3116
Austin(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 9:12pm
You need a BFH.
"Better By Design"
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 3:22am
guess i could mention dremel tool?
Post Options Post Options   Thanks (0) Thanks(0)   Quote outlook6 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 8:08am
Many thanks to you all for the great responses.  I found a pilot bearing puller on line that I ordered.   When it gets here I'll try that first.  If that fails I'll try using my welder.  In the meantime I'm keeping the bearing doused with PB blaster.
Thanks again and best regards to all.
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 8:25am
2 L shaped pry bars made from old screw drivers or such with the short part of L long enough to reach the edge of the outside race , then evenly applied pressure to both bars. Some heat to case area may loosen the bearing in race also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 10:52am
A slide hammer works the best to remove a bearing in that position. Two slaps and its out! Then you have the bearing in whole to get the number off to order your new bearing. A tool rental store will have that tool pretty cheap to rent out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote outlook6 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 8:42am
At my age I should have known that there's a correct tool for every job.  I found and ordered this bearing puller on Amazon on Monday and it arrived yesterday.  It took just a couple of minutes to pop out the bearing.  Thanks once again to all for the help.
Jim
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 8:42pm
Yep, multipurpose blind bearing puller.
I have a slide-hammer puller... mine's from OTC, but Horror-Fright has 'em too, and they're okay.
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 6:57am
 Bearing puller, slide hammer and/or heat. If you use heat make sure you don't get the casting to hot or it may break.
Thanks & God Bless
Dennis
SteveC(NS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 10:10am
Jim, the bonus is that now that you have the tool you'll prolly never need it again LOL.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 11:00am
But you can make money from loaning it to your neighbors for free.
