Changing tire on planter unit
novacane View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote novacane Quote  Post ReplyReply Direct Link To This Post Topic: Changing tire on planter unit
    Posted: 25 Feb 2012 at 2:52pm
Can anyone tell me the best way to install a new tire on the rim of a corn planter unit??  I got the old one off but it was half wore out  a little easier to pry off rim. Not such as good of luck trying to get the new one on.  this is a rubber tire  i think 7.00 x 18
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2012 at 6:01pm
soap and water mix
Post Options Post Options   Thanks (0) Thanks(0)   Quote novacane Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2012 at 9:51am
Thanks JoeO  I will try that  but boy i dont know just a  pain in the arsh.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2012 at 8:43pm
Use a rubber lube like the tire changers use and it will slide right on.  MACK
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 7:59pm
Here's how I do it; I lay the rim flat on the shop floor, then I take a 4 inch diameter by 8 ft long pipe and stand it straight up and down in the center of the rim. Then I set the loader bucket down on the top of the pipe to hold the rim so it doesn't move. The length of the pipe keeps the loader up out the way so I have room to work. Then I have a couple of inch and a half diameter pipes about 5 feet long that I cut out notches half way around on one end, that I use to pry the tire on with. I do lube the tire up really good with soapy water first. Works for me. Darrel
