Cost Reduced 200
WALLACE220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WALLACE220 Quote  Post ReplyReply Direct Link To This Post Topic: Cost Reduced 200
    Posted: 22 Feb 2012 at 3:47pm
I just purchased a 1973 200 and according to the serial number it is Cost Reduced model, what is the differance between a so called regular priced 200 and a cost reduced 200?
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 3:55pm
they used up the rest of the 190xt rearends that were coming apart LOL
just kidding.  i didnt know there was such a thing
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 4:28pm
Have never had one but I know they went to the gated power director lever, when it wore it would lose pressure and cause problems, I think a little less tin work and maybe a lighter front end support. just things other people told me.
oldironguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldironguy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 9:20pm
I'm just guessing here but I once owned a green and yellow four cylinder 1010 that was marketed as the "Special".  It even had "Special" decals on the sides.  Turns out that "Special" meant made to sell at the lowest possible cost..i.e. stripped down with no optiions included.  For example, all the other 1010 models (there were quite a few) had adjustable cushion seats. The "Special" had a tin seat.  Could "Cost Reduced" mean something similar?
MI8050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI8050 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 4:24am
Smaller tires, different cab (no visor I think), less frills.
HARVESTMOONPULLER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HARVESTMOONPULLER Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 2:42pm
I have one too. It was hard to figure out what cost reduced meant until i brought it home and parked it beside my xt ser.3 and started comparing how things were built. Cut corners big time on the cost reduced 200.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 6:18pm
The front casting is hollow compared to a full block , 500 lbs lighter too , the transmissions seem worse , powerdirector control problems , brakes suck , engine liners have more electrolisees trouble if you dont use conditionor in the cooling system, a series 2 XT is a good one
AndrewGubbels View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndrewGubbels Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 10:27pm
If you look at the parts break down the biggest things changed are the power director gate instead of the push down style.  Also the Gear shifter is taller.  Same transmission setup.  They had a different seat on them in the suspension area that was fine but not as nice.  They had a single headlight on them in each fender vs. two. They had a different air filter than the earlier ones.  The brakes are a different style I cant says as if they are any worse at all.  If they are in shape they work good.  They hung on to the dry brakes to long on them.  Other than that on the parts break down there is not anything that much different as I can see.
Andy
Andrew Gubbels
Gubbels Restoration
smallfarmer83 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smallfarmer83 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 11:05pm
What serial number's did the cost reduced 200 fit into..going to look at a 200 tomorrow, just curious, thanks.
