High Idle for D-17
Bcjk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bcjk Quote  Post ReplyReply Direct Link To This Post Topic: High Idle for D-17
    Posted: 18 Feb 2012 at 5:14pm
I replacced the swivle that is under the gas tanl that hooks the throttle rod to the rod that comes back from the motor. How do I get the correct RPMs out of the tractor ? Wide open now it is about 1750rpms? Hope I made this clear. Would like to find a shop manual. I was a  AC dealer in the 70"s Jim Kiewiet
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2012 at 6:11pm
Mine runs 2000 on the dot. But I don't kno if its right
190XT,D17and 7045
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2012 at 6:50pm
If you reinstalled the ball socket in exactly the same spot on the link rod, it should run the same speed as before. Adjust/position things differently until you get the correct speeds (idle and high idle).
