wd45 gear oil?
wdforty5 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wdforty5 Quote  Post ReplyReply Direct Link To This Post Topic: wd45 gear oil?
    Posted: 17 Feb 2012 at 7:08pm
I checked the oil level at the square headed (3/4 inch or so) bolt under and behind the clutch lever. Oil level was about an inch or so from the top. Should it be at the very top, and I would assume 80w90 gear oil? Anyone ever run hy/tran in the rear end?
One more...how about capacity if I wanted to change it.
Thanks fellas!
smokey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smokey Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 7:43pm
OK, You ready?
Rear end & Trans 17qts 80/90
Hyd 6 qts non-foam like AW-46
This is what my owners manual for the wd-wd45 said went to the local oil gas company and they converted it for me, there should be 3 drain plugs under the tractor to drain, just dont do what I did! Put the AW46 oil the trans, should have been hyd. I had a DUMM moment.
Good luck..
Post Options Post Options   Thanks (0) Thanks(0)   Quote wdforty5 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 7:47pm
Originally posted by smokey smokey wrote:
OK, You ready?
Good luck..
 Thanks for the help, I can sure see how a fella could accidently fill the hyd. fill with gear oil or vice versa. I have an operators manual but it didnt say how full is full though. Did your owners manual mention the correct level? Im just wondering if I should fill till it comes out. I probably wont be changing for a while.
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote smokey Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 8:02pm
NO, sorry but I just put in what it called for and it looked about right, I could see the oil in the bottom of the fill hole just below the plug, and the hyd. oil was right at the full mark on the dip stick, I drained all mine as I'am rebuilding a WD that had set for some time didn't want no water in there but I opened up the hole rear end to check bearings and seals also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 9:30pm
Use hydraulic wet brake oil all the way.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 9:48pm
Originally posted by wdforty5 wdforty5 wrote:
Anyone ever run hy/tran in the rear end? Thanks fellas!
I have had Universal Hydraulic fluid in my WD45 since 1980. Works fine in the tranny, differential.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 11:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 11:26pm
Like Mack says.Hy tran in both.Fill 2 plugs rear of hyd fill(same levels) full up.
