need spec help on WD
Nautyboss View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nautyboss Quote  Post ReplyReply Direct Link To This Post Topic: need spec help on WD
    Posted: 17 Feb 2012 at 3:51am
Can anyone provide me with torque, clearance, etc. specifications on the crank and head for my 52' WD?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 7:27am
I think bearings should be between  .002 and .004 for clearance. Sleeves should extend above the deck .002-.004 also.
You can do a google search for torque specs for about any size or grade of bolt.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 8:26am
Head Bolts=90ft-lbs; 3/8" studs=25ft-lbs
mains=85 ft-lbs
Rods=70ft-lbs(castelated nuts); 40ft-lbs(locknuts)
Valves-0.012" hot
Valve Springs=2 13/32" free length; replace if more than 1/16" under
Liner Stickout=0.002-0.004"
Rod nut clamp bolt=20ft-lb
bearing cap insert stickout=0.0055" each side(block and cap)
Bearing clearance=0.002-0.003"
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 8:38am
Them's D17 torques. WD's were less.17's had better bolts
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 11:46am
Guess my Jensales WD/WD-45 service manual is wrong.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 12:59pm
I'm not taking sides here but, My well used and oil covered for-real Allis Chalmers shop manual has the same INFO in it that Greg posted. Embarrassed
I think I have used up all of my IT shop manuals for fire starting after they send me down the wrong path to many times. The funny thing about burning them up; is they didn't even burn that good for what I payed for them! Ouch
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nautyboss Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2012 at 8:24pm
Thanks, I appreciate the info. Can you tell me what the ring gap is supposed to be?
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2012 at 9:05pm
Typical ring gap is .001 to .0015 per inch of cylinder diameter.  This is the specification for a new ring.  I don't know what the maximum allowable gap would be.
