Loader on 160 - Need Advice
geb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote geb Quote  Post ReplyReply Direct Link To This Post Topic: Loader on 160 - Need Advice
    Posted: 15 Feb 2012 at 9:55pm
I am going to put a loader on a 1970 model "One Sixty".  Is the hydraulic pump large enough to handle the regular duties as well as the loader.  Also what and where is the best place to tap into the system?  Is there a fesible way to mount a front pump?  Any help and/or advise will be greatly appreciated.  Thanx in advance.
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 6:42am
160 should run a loader just fine and anything else for a tractor of that size.  Just plug into the rear remotes.
Edited by TexasAllis - 16 Feb 2012 at 6:43am
1944 Allis C
1960 Allis D-17 LP
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 7:34am
Two IFs
1.  IF it were me
2.  IF the remote valve levers are the same as the 190, with the very aggressive "detents"
I would plumb a different two or three spool valve into one of the factory remotes.  I think you will eventually get very frustrated trying to use a loader with the factory setup for the levers.
Plus this gives you one open remote valve for some other use as needed.
Still in use:
stray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 4:41pm
If you use the factory remotes to run the load, be sure to put ball valves between the quick coupler and loader bucket hoses, so you can shut them off with the loader lifted up and bleed the pressure off and then unhook the hoses to do other things. and still plug them back in easly
1969 190XT series 3
geb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote geb Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 1:19am
The loader has it's own controls.  I just need flow and pressure and the ability to use three point hitch and rear remotes at the same time as the loader.  Thanx
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2012 at 10:29am
Just adding a tee in the pressure line will not work. The system is open center, You will need a diverter valve or a power beyond setup. If you don't none of the hydraulics will work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2012 at 5:26pm
If both valves are open center you should be able to hook them in series (the outlet of one to the inlet of the other) and be fine. But you will only be able to use one fuction at a time.
1969 190XT series 3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2012 at 7:27pm
If you hook them in series, the first valve should have power beyound. If not, it may not work properly.
You may still will only be able to use one function at a time. Load checks on the work ports will keep from back feeding from one function to the other.
