Model 6070
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Topic: Model 6070
    Posted: 15 Feb 2012 at 8:27pm
I'm looking at at 1985 A-C 6070.  Do any members have any experience with this model of A-C.  I'm only use to WD's and D series and gas engines.  This may be the last tractor purchase I make and want to make sure I get a good model.  Any assistance positive or negative would be so much appreciated.  Thanks!
BLee Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BLee Mn Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2012 at 8:38pm
 I just bought a 6080 and really like it,  6070 85 model should have the updated crank and block, also engine preheat, there were issues with earlier models spinning rod bearings when starting cold, they added a external bearing/ support on Crankshaft as a fix , makes a nice loader/chore tractor for me anyway, i think you would like it!!
Cowboy UP
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2012 at 9:46pm
I have an 85 6080.  Excellent tractor to drive.  Handles very nice, easy on fuel, lots of power, good visibility.  Given that you are currently using the D series, it probably will not get overworked.  Should be able to last a long time.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2012 at 9:56pm
Just have to ask what is the S.N.? How close to the end of the line is it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2012 at 10:06pm
Haven't captured the Serial number, however it is decaled A-C and not KDH so, it is pre-buy out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2012 at 10:11pm
it was a thrust bearing problem not a rod bearing problem
ky wonder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ky wonder Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2012 at 7:34am
many of the 6060s/6080s have reached the 10000-11000 hour mark from what i have observed on the net, they are stingy on fuel.
i have a 82 model 6060 with 2900 hours, that is basically the same tractor with an 8 speed transmission and no intercoller rated at 63hp, and  i love it!
the pto system is a fiat design that uses two seperate levers to power the pto, the pull up knob on the left of the seat engages the main pto drive, the long pto lever on the right is used for engaging and disengaging while working with a pto powered implement'
be sure to leave the long pto shifter by your right leg in the on posision when not in active pto use, and use the pto engagment lever on the left to disengage pto system when not using a pto  powered implement.
 leaving the knob engaged and the lever turned off puts a great deal of pressure on the clutch.
the 6080 had the same transmission as your 6070 and it used a larger clutch that created problems with the front thrust bearings on the 6080 series of tractors, resulting in some early enjine failures, the problem was not as evident in the 6060 tractors because of a smaller clutch, i do believe that Allis enjineers had these issues solved by the time they released the 6070 to replaced  the 6060
the last tractor built by allis chalmers was a 1985 6070 sn 1972
Edited by ky wonder - 18 Feb 2012 at 7:51am
i like old tractors of all colors
