What to Paint on a D Series Gas Gauge
Michael (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael (WI) Quote  Post ReplyReply Direct Link To This Post Topic: What to Paint on a D Series Gas Gauge
    Posted: 12 Feb 2012 at 2:11pm
Those who might remember to when your D series was new, how much of the gas gauge face was painted?  My question is specifically about the trim ring holding the glass in place.  This tractor has had a paint brush re-paint in the past and there are spotty remains of paint on the trim ring.  Should it be painted and most of it has worn off or was that just over-painting from the brush?
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2012 at 3:43pm
Paint the trim ring, I dont remember any sliver showing thru when new.    The rest of the guages had all sliver trim ring showing thru.  HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2012 at 5:06pm
Thanks for the info Skip.  When you say the rest of the gauges had the ring showing I am asuming you are talking about the 100 series?
NickT(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NickT(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2012 at 6:54pm
He means amp. temp. etc. HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2012 at 8:10pm
Ah yes, I knew I was over thinking it and missing something obvious.  In any event I have the gas gauge all painted with a neoprene float installed.  Hopefully I won't need to pull the gauge again.
