HD6G track removal/Parts
Arthros View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Arthros Quote  Post ReplyReply Direct Link To This Post Topic: HD6G track removal/Parts
    Posted: 09 Feb 2012 at 11:33pm
I am parting out an old HD6G loader and need help on removing the tracks. Does anyone have a detailed picture on where the pins are to take out the tracks and how they come out? Also does anyone know the weight of this machine and what some of these parts would sell for? Thanks in advance for your help.
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2012 at 6:35pm
the master pin is dimpled on the end of the pin in the center. it is as simple as driving it out. it is as hard as driving it out. backup the inside of the track with a piece of pipe blocked against the frame so the link doews not move and spread as you drive it out. it may require some heat on the link to get it to move. my hd5g witha winch on the back weighed 18000 if i remember right. might be a little high on the weight. my hd5b with dozer blade weighs 12ooo lbs. where are you located and are you selling everything as parts? good luck.
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2012 at 8:11pm
If the motor has the second design intake manifold I would be interested in buying it. If the motor has the cast iron exhaust manifold I would be interested in that also.
skybum1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skybum1 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2012 at 9:20pm
I need the water pump off your hd6g if you still have it.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 4:36am
I am still have some HD6G water pump
Post Options Post Options   Thanks (0) Thanks(0)   Quote skybum1 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 6:19am
Hector,  Yes I still need a water pump.  Does your pump look like this one?  Can you post picture of yours and way to arrange shipping and payment?
Thanks,
John
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 12:32pm
 I am going to my small shop and get the part number on the water pump and getback to you.
This page was generated in 0.449 seconds.
