flushing out a coolant system. |
Post Reply |
ChuckLuedtkeSEWI
Orange Level Joined: 11 Sep 2009 Location: Jackson, WI Points: 1826 |
Posted: 30 Jan 2012 at 8:47pm |
Coolant on the D19 is kind of dirty looking and when I drained out the radiator to get off the front bolster, there was alot of gunk that came out. Flushed the radiator a few times before I put it back on. I just filled up with water right now and it is in the shop so it won't freeze but I would like to flush things out really good before I spend the money on new antifreeze and waste it putting it into a dirty system. I know on vehicles they make those add on kits to run a garden hose and flush the system, but how can I clean this thing out good. Is there an additive to add that will loosen things up? Would like to get it done this week as temps are mild and I can pull it outside and get it cleaned out. Any tips would be appreciated. |
CTuckerNWIL
Orange Level Joined: 11 Sep 2009 Location: NW Illinois Points: 22823 |
Chuck, I have had issues with my 38B over heating after mowing for an hour or so. Last summer I bought a jug of NAPA radiator flush. I added it to the water, ran the engine up to working temp a couple times and then drained it. A lot of nasty looking stuff came out but I wasn't sure it was clean, so I added some washing soda and ran it up to temp again. It wouldn't warm up good because I just had it idling in the shed so I put a canvas over the rad and finally got it warmed up. My next step, hopefully tomorrow will be to put a gallon of vinegar in her and run till warmed good. Then I hope I won't be wasting antifreeze by filling it up for next summers mowing chores.
I would hate to have to clean it up like I did the WC. I had it completely tore down and cleaned everything but the rad in my electrolysis tank. |
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7332 |
I put some water in it with the garden hose and shake the rad around a few times, and dump it out. Then put water in another hole on the rad and do the same thing. Keep doing it until the water is clear coming out of it.
ChuckLuedtkeSEWI
I think I got the radiator pretty good, but I have a feeling that the block is probably just as gummed up if not worse. I think I will end up pulling it outside and flushing water through the hoses from the bottom and the top until it comes out clear.
Boogerowen
Orange Level Joined: 23 Apr 2011 Location: Mannford Ok Points: 431 |
Chuck, flush your block out real good, then flush your radiator real good seperately, then add good, new, fresh anti-freeze, Good, new anti-freeze has rust inhibiters in it to take care of the electrosis that causes the rust.....
Steve in NJ
Orange Level Access Joined: 12 Sep 2009 Location: Andover, NJ Points: 11796 |
I use a product called Nalcool. Its purple in color, and you add it to the cooling system. It cleans as you use the vehicle (in this case Tractor) and you can leave it in for a few days while you use the Tractor. It'll clean while your working the Tractor. After a few days, drain and flush the system, and add your 50/50 mix of Antifreeze and water. This stuff does a great job cleaning the inside of the radiator, as well as the rest of the engine block. Its not that caustic, so its easier on you as well as the environment. Napa sells it under their brand name, but its still the same stuff. Purple in color. You also can add a little to the cooling system after its flushed with your new Antifreeze as it will clean while you drive...
Steve@B&B |
powertech84
Silver Level Joined: 17 Oct 2009 Location: Wisconsin Points: 467 |
I'd recomend you run up the road to the deere dealership and get a jug of PMCC2638. I've had a lot of success cleaning up cooling systems with this stuff. Just watch for leaks after you get done. Its pretty common for water pumps and sleeves to start leaking when you remove the sludge thats blocking the holes.
Dipstick In
Orange Level Joined: 11 Sep 2009 Location: Remington, In. Points: 8602 |
I went to bed one night on top of Mt. Eagle in Tn. In the morning I looked out the front window and saw a huge puddle of antifreeze. The oil cooler had let go and oil was pumped into the cooling system. Temp was normal but I only had about 5 lbs. of oil pressure. I bought oil and filled it up and limped into Chattanooga to a Mack dealer. 9 hours of cold garden hose running in the radiator,at $50/hr, one new cooler,full of straight water and ONLY 942 dollars later I was back on the road. (would that classify as a rip-off?) Called my buddy at Peterbilt in Indy about what to do and he said to buy liquid Calgon dishwasher liquid and pour the whole jug in the radiator, run my trip and when I got home to drain and flush it. Also he told me to do this for a week running the truck and clean it out every weekend until it was clean. It took 3-4 weeks to get it clean, and then I filled it with distilled water and antifreeze. It was amazing how clean it got the system. I traded that truck later for a newer one and I think it is still hauling off the farm in western Ohio.
Stan IL&TN
Orange Level Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Like Dipstick I would use distilled water and keep the minerals out of the clean system.
1957 WD45 dad's first AC
1968 one-seventy 1956 F40 Ferguson |
Gerald J.
Orange Level Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
The hose connection kits plumb into heater hoses. Might not be an option on the D19. The kits from NAPA are about $1.79.
Gerald J. |
Rawleigh
Orange Level Joined: 14 Sep 2009 Location: White Stone, VA Points: 421 |
Cascade dishwahing detergent (nonfoaming) was the old stand by to get oil out of the system. Cummins Restore + works well on scale and rust.
Gerald J.
As of last year, dishwashing and laundry detergents have no phosphates and are poor at cleaning, even causing aluminum to turn black.
Gerald J. |
Bill_MN
Orange Level Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1466 |
if you really want to do the job use Permatex Heavy Duty Radiator Cleaner. be careful as it contains strong hydrochloric acid which dissolves the deposits and rust, make sure your radiator is solid or it will turn into swiss cheese like mine...fortunately I was replacing it anyway
JoeM(GA)
Orange Level Joined: 12 Sep 2009 Location: Cumming,GA Points: 4656 |
washing soda works like the old Calgon and Cascade used to
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
captaindana
Orange Level Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2462 |
Great post! Hey, where does one buy washing soda anyways?
Dipstick In
I can get it in my little grocery and I think in super wallyworlds, dont know bout little ones.
JoeM(GA)
Captn' most grocery stores have it in the laundry soap area
Gerald J.
Your water softener makes it substituting sodium for calcium. Its sodium carbonate. Why water from a softener will wash without added soap or detergent if the water was really hard.
Gerald J. |
Ted J
Orange Level Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18821 |
Is 'washing soda' Arm and Hammer laundry soap? I searched Wallyworld for 'washing soda' and came up empty. Whats the name for it?
Post Reply | |
