HD11 Sprocket Removal
Argo2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Argo2 Quote  Post ReplyReply Direct Link To This Post Topic: HD11 Sprocket Removal
    Posted: 30 Jan 2012 at 3:11pm
After I get the track off how do I get the rear drive sprocket off? Do I need a hydraulic puller?
I have to replace the main oil seal behind the drive sprocket. Any one ever done this in this and what kind of job is it?
Mactractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2012 at 4:05pm
If you are lucky, driving wedges in between sprocket and drive housing loading the sprocket with tention, then using a copper or aluminium buffer on the end of the shaft to protect it, hitting on the end of the shaft, or lowering the bottom of the sprocket onto hard surface, and hitting down onto top of sprocket may be enough to spring it off the spline. Unfortunately, HD6 is usually the biggest tractor these methods work on. With HD11 and bigger, Hydraulic pull/push gear is usually used to do sprockets. Track shops have that gear
Steve allis dozer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve allis dozer Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2012 at 5:08pm
if you use a puller make sure to leave the nut  on the shaft to catch the sprocket , undo the nut a couple of turns ,
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2012 at 7:14pm
give the sproket a few whacks with a sledge hammer,  just took the sproket off 2 HD16's and luckily in both cases it popped off.  and your seal is a positive type not a lip type, probably not leaking at the sealing rings but behind them.
good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote Argo2 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2012 at 7:55pm
What do you mean leaking behind. I was surprised to see what the new seal actually looked like. Spring loaded contraption.
Anyone know what this machine weighs with dozer and winch?
Edited by Argo2 - 30 Jan 2012 at 7:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2012 at 8:03pm
one side is not spring loaded its cemented to a gasket.  sometimes the spring loaded side can leak through also.   where on earth did you find a new one?
HD11 is around 23,000# and up,  depending on series and configuration
Edited by CAL(KS) - 30 Jan 2012 at 9:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2012 at 3:26am
HD11EP with blade, winch, and ROPS roll cage goes over 33000. Series B 11 with that gear will be over 35000
This page was generated in 0.453 seconds.
