WD45
smokey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smokey Quote  Post ReplyReply Direct Link To This Post Topic: WD45
    Posted: 14 Jan 2012 at 6:49am
I picked this tractor up 4 or 5 yrs ago and she was tired, saved it from going to the junk hope to get some Pic's of it on here as work progess go's along, it's a tough looking  old wd45 ser#234678 beleive a 1956, 4 bolt wide front, I have been picking up a part here and there, So I think have enough to work on her and maybe bring here to life!
I'll surely be asking for HELP on this one as I go along, My nephew said last night WOW you'll have your work cut out on this one as we loaded it on the trailer at Dads to bring it to my place.
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2012 at 7:44am
Best of luck! You will be glad you did it when its over!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2012 at 11:29am
GOOD LUCK and this is the spot to ask, as you know.
Post Options Post Options   Thanks (0) Thanks(0)   Quote smokey Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2012 at 3:21pm
Is there sealing O-rings on the sleaves on a 45 engine Like that on a 301 ?
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2012 at 4:27pm
yes there is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote smokey Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2012 at 7:54pm
Ok I got Started working on the WD45, Here is some Pic's I was going to just pull the old Engine and put in one that already runs, but this one wasn't as bad as I thought it would be, Already has M&W kit in it so I'am going to run some of the pic's then ask some Qustions on the last couple pic's.
Now I need to know if the flywheel will make it with these cracks? the clutch plates it self looked to be fairly new.
And last but least crank looks fine and has been redone, but I believe the bearings are 30 over, this was what I found on the bearing.
DAB 72
67-25
7440=T
030
and I'am going put in new bearings.
