jack screw bolts 190XT?
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: jack screw bolts 190XT?
    Posted: 30 Dec 2011 at 5:36pm
Hi guys if I remembered the terminology correctly my friend asked me to inquire as to the availability of jack screws for a 190XT. If I have the name messed up he wants the 3 bolts that screw into the center hub which move the hub on the axel. Are any of these bolts available? Thanks, Dana
smokey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smokey Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2011 at 5:47pm
I do think they are available yet I picked 3 of them up a couple yrs ago, they was a little salty on $ if I remember right! but you won't move them hubs without them bolts, just careful not to put to much power on one bolt at a time you could break the casting where you thread the jack bolt in,
 Good luck
If you was closer I would let you use mine, lol
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2011 at 7:17pm
Here's what they look like.  Someone suggested using a grade 8 bolt and a hardened slug...
ALLIS EXPRESS!
This year:
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2011 at 8:29pm
the smaller ones used up to D21's are different than the large ones like 210/220, and 7000/8000 series tractors used. The smaller ones are not as pricey, and I think they are a standard thread pitch/diameter.
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2011 at 9:12pm
SS$105.00 GOOD,USED,ORIGINAL. 785-353-2392
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2011 at 7:37am
The larger ones that fit the 210/220 are the same as the ones that fit the Case IH 9110. I use them for both here, don't know the cost as they came with the tractor.  The smaller ones I have for the 200, XT I bought from AGCO in the lat 90's and I think all three wereless than $30 back then.
