Will 8030 Pull 3600 12/23 Kinze?
AlfordFarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AlfordFarms Quote  Post ReplyReply Direct Link To This Post Topic: Will 8030 Pull 3600 12/23 Kinze?
    Posted: 22 Nov 2011 at 11:41am
 Will a 8030 (stock) pull a 3600 Kinze 12/23 planter, Flat and Hill Ground?
(3)G,(2)D15,200,185,8030,8050,R66
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 11:57am
We pull an old rearfold 12/23 Kinze with an 8070PS FWA. We are also on 36" row corn / 18" row beans. Our farms lay fairly flat hear in NC Iowa. I can't say that the 8030 wouldn't, but it would sure know it had a load pulling up hill with a full load of beans.
ScottinSWIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ScottinSWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 12:32pm
We pulled that model planter with a JD 4450 2wd for several years and got along fine.  Horsepower will be similar between the two.  We really needed some weight on the rear of the tractor as we were running without fluid in the tires and in certain cases it was a little light.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AlfordFarms Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 12:41pm
My 8030 is  a  PS, FWA. I am having the injector pump rebuilt and will prob have it increased about 10%, I am going to add duals to the rear and maybe wheel weights. I am running 20.8 38's now. I hate to go to a 8 row b/c still running 6 row corn head, and as far as price it would be cheaper for me to go to 12/23 instead of 8-15 and add a corn head.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMB(wcIL) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 12:44pm
I have pulled a Kinze 12/23 with our JD 4440 2wd and now with a JD 7800 2wd on the hills and flat ground we have, you sure can feel it when its full of beans.  Some of our hills I can only plant down hill because I don't have enought traction to climb it.  Andy
Dean/MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean/MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 3:44pm
My brother pulled a White 16/30" this spring and had no issues with power on hilly ground other than down shifting a gear. We did get it stuck a couple of times but it was so wet we didn't even start planting till June 2nd. The tractor is a stock 8030 but it seems to have close to the power of our 8070.
Edited by Dean/MN - 22 Nov 2011 at 7:07pm
HD16,917H,185,7050,8030FWA,8050FWA
Post Options Post Options   Thanks (0) Thanks(0)   Quote ScottinSWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 6:53pm
 I understand how changing equipment can snowball money wise.  We traded a few years ago from a R62 with a 6 row head to a R75 with an 8 row and we were planting with a 12/23.  That only lasted one year and then we went to a 16/31 in which the 4450 was too small to pull so we had to buy a bigger tractor to pull the planter.  By the way I see you have a R75 also which has been a real beast to us compared to the 62's we had through the years.  We traded this year for a R76 and couldn't be happier.  The Kinze 3600's are great planters and I think the 8030 will definetly handle the load as I would say the Allis is a heavier built machine than the 4450.  We had a 2wd 8030 that I would of not been afraid to plant with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean/MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 7:05pm
Our ground is definitely not flat. Some of our corn ground eroded so bad that we are adding none farmable dikes in several spots. As far as pulling 12/23 you should be ok as long as you have enough weight to not spin out.
Orange, in the pic you are talking about there is a patch of meadow/low land to the right of the pic that we had to plant around so turning around actually straightens out the field.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 8:08pm
Scott, we did the same thing, R62,R75, and now R76. It sure is amazing how much bigger the 76 is over the 75. The base machine ran great, but ours has the GPS stearing and it isn't what we thought it would be. Do you have it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ScottinSWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 8:26am
  Unit3     We had the Agco autosteer on the R75 just for the fact that it was on there when we bought it used.  That machine our dealer got in from another dealer in Ohio that had a customer that wanted it to shell corn with, but could never get it to work right.   We never honestly messed with it the 2 yrs we had the machine.   Should have tried it in beans at least.  The R76 is an improvement also, especially the unloading auger.  They really sped up the unloading time,  plus we no longer have the feeder house plugging issues like we had with those 62.s
This page was generated in 0.250 seconds.
