HD6 Dozer
MD Norton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MD Norton Quote  Post ReplyReply Direct Link To This Post Topic: HD6 Dozer
    Posted: 20 Nov 2011 at 11:15am
I have a HD6 Dozer for sale, starts and runs good, automatic transmission, external roll cage, 2 rear hydrolics.  Needs a little work on the oil return port.  Gasket has slipped down over the return port so the oil from the final drive to the filter housing is slow causing loss of transmission pressure after an hour or so of use.  let it set a couple hours and it pulls good again for a while.  Not an expensive fix, just time consuming.
CaidAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CaidAC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2011 at 7:29pm
What are you asking? When you say time consuming-how long do you think. What's undercarriage like.
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 4:15pm
What are you asking for it and where is it located
Post Options Post Options   Thanks (0) Thanks(0)   Quote MD Norton Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 5:51pm
My HD6 is located near Alamosa Colorado and I am asking $8000.  To fix the final drive gasket would take maybe 3 hours to take it apart then a couple hours to clean off the old gasket and get it ready to go back together.  then mybe 3 hours to reassemble depending on how fast you work.  If you're creative you may be able to get to it through the screen housing.  I was able to ge a little more flow with an arrow, but not enough to fix the problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MD Norton Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 5:55pm
The under carriage is at least 70% with no visible wear.  The tractor has less than 2000 hours on it.
This page was generated in 0.207 seconds.
