IH 2350 Loader on Allis possibility?
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Topic: IH 2350 Loader on Allis possibility?
    Posted: 09 Nov 2011 at 9:20pm
I have been looking around for an All-Terrain type forklift, but havent been having any luck. I am primarily wanting to unload seed pallets, and be able to pick up and move things like combine headers without having to hook up.  I saw an IH 2350 that is supposed to lift something like 5000 lbs "Breakout force" and 3500 to the full height. I think that weight range would suit my needs.  I dont know what brackets (if any) come with it, but can it be modified to fit an Allis tractor?  My main possibilities would probably be 190 XT, 210, or 7045.  Anyone have one or use one?  Thanks in advance
m16ty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2011 at 9:28pm
I've adapted several different brand loaders to different brand tractors. I haven't done the one in question though. The main thing to check is the frame width of the brackets if it comes with any. This makes fitting it on the tractor much easier.
Another problem you may run into is the Allis tends to be wider in the front grill area than most tractors. Make sure the loader arms are wide enough to clear the grill.
Just about any loader can be made to fit any tractor. Some are much easier than others though. The last one I did was a JD 175 loader on a Farmall 544. All I had to do is drill a few new holes. Best thing to do is get out your tape and take some measurements of your tractor and compare them to the loader.
Edited by m16ty - 09 Nov 2011 at 9:29pm
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2011 at 9:41pm
There is a guy down the road that has a 2350 on a 7040. Im not sure what was done to make it fit, but it does and works well. The "breakout force" of a loader is not the lifting capacity but the force the bucket has to curl under a load. If the loader is rated for 3500 it will lift 3500 throughout its lift range. The 5000lb "breakout force" will not make the loader lift more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2011 at 9:45pm
Thanks for clearing that up for me Dan. I didnt know if break out force was what it could lift off the ground (ie, breaking out a stuck rock or something), or what it meant exactly.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2011 at 3:40am
if you have a 3-pt hitch on something..go to www.gnusemfg.com they make a strong fork lift that attaches to your 3 pt
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2011 at 4:19am
Anything is possible if you have enough money.
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2011 at 5:16am
My yard forklift is a JCB 525 telahandler. 4x4 with 5000 lb. capacity to 22.' It has a Perkins engine and is the handiest thing you will ever own. Mine is a 1988 and I'm sure you could find a good one for under $10G. We also have a material bucket. We have 2 newer larger JCB's as jobsite machines. The big one  can handle 10,000 lbs to 44'.
BStone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BStone Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2011 at 5:35am
Don't have a 210 so I'm not for sure but I don't think the 190 would be my choice for a loader tractor.I had one and had trouble with the light front ends the 190's have.Have a 7045 and makes a much better loader tractor.
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2011 at 7:29am
most AC's come with only 2200lbs hyd pressure.  you will have to shim the pump to 2500lbs.  It's a cheap ez job.  without making sure the pump puts out 2500lbs, you may be disappointed in the lifting power.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2011 at 9:52am
I have a 2250 w/ joystick I put on a D19. Made the brackets. Couple hundred bucks in steel and some time. Going to put it on the 190 hopefully soon. D19 isn't the greatest loader tractor.
Wink
I am a Russian Bot
