Split the tractor?
Redkap (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redkap (IL) Quote  Post ReplyReply Direct Link To This Post Topic: Split the tractor?
    Posted: 21 Nov 2009 at 10:23pm
I drove my WD45 to the field today to haul a few straw bales in the dirt scoop (deer blind).  When I got to the field, I started hearing a whining noise in the transmission.  I proceeded to go the last 200 yards in 2nd gear, and the tractor felt like it was under a load.  When I went to leave (figured I'd try to limp it home) it "surged" a little as I started, then bogged down and made a little "pop".  Of course I shut it down.  What did I do???  I assume I'll have to split the tractor to find out what's going on.  I pulled it home in neutral with no problem.
I overhauled the engine a couple years ago, but have never worked on the tranny.
Thanks,
Kevin
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 6:31am
Has the trans got oil in it. I would probably take the top off the trans first. Then you could push the clutch in and get it in nuetral and see if the front half will turn. You could just see if it will run in nuetral with the clutch out. JP
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 7:16am
If you pulled it home in neutral without a problem, there must be oil in the transmission and that is not where the problem is. How about a roller on the hydraulic pump eating it's pigs??
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 8:00am
I didn't notice that he "pulled it home".JP
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 8:34am
Pinion bearing locking up. Most likely from lack of oil.
  Let us know.   MACK
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 9:00am
My D14 acted that way when I pulled the Traction Booster lever all the way down with no load.  Don't know how that is controlled on a 45.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redkap (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 9:36am
First thing I checked was the oil, and it's full.  I'll check it out from the top.  Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 10:12am
start the tractor in neutral and see what it does. engage pto and see what it does. test huudraulics--- push in cluthch and put in 1st gear.. let it out... put in 3rd gear. let out the clutch.. noarrow down whats going on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 11:55am
Exactly WHERE did you check the oil???There are two square headed check plugs on the left side of the torque housing....one in behind the clutch pedal and the other just ahead of the clutch pedal and then the hydraulic dipstick ahead of that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redkap (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 12:00pm
I only checked the dipstick.  Should I open the plugs too?  I didn't know I needed to be checking places other than the dipstick. :-(
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 12:11pm
The dipstick is only the hydraulic oil !!!!!! Check the two plugs.....they should be full of 80-90 wt oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redkap (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2009 at 12:59pm
Well, I feel like a DxxbAxx.  Finally had time to pressure wash the tractor today and push it into the shop.  Doesn't look like there's any oil in the rearend.  I'm going to stick a rod into the holes to find out if it's completely dry.
Then I'll probably jack it up and see if the wheels will spin.  Probably inspect it from the top to see what I've messed up.  Can't imagine that I can just add oil and go.
Any other advice appreciated.  I guess I need to get an operatiors manual to make sure I don't screw something else up.
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2009 at 3:33pm
Pull the differential cover off the back, you might be able to see real quick what is happening.
This page was generated in 0.057 seconds.
