7060 power shift
DansXT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DansXT Quote  Post ReplyReply Direct Link To This Post Topic: 7060 power shift
    Posted: 27 Oct 2011 at 12:06pm
What would cause 5th and 6th not to engage while the rest of the gears do?
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2011 at 3:00pm
check the linkage first and see if the lever is moving the control far enough.
              Shawn
190XT,D17and 7045
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2011 at 5:12pm
So, does it "click" into 5th and 6th and stop moving?? or does the lever not move that far ahead??
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2011 at 6:29pm
1
Edited by Lester - 27 Oct 2011 at 6:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2011 at 6:30pm
1
Edited by Lester - 27 Oct 2011 at 6:35pm
I got a 7020 powershift not too long ago and it also will not shift down to 4th like it should with clutch pushed halfway down . It wants to kill the tractor. Also it is easy to miss a speed and seems like there is too much play in the shifter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DansXT Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2011 at 7:33pm
tractor does lurch a little in 5th and stops, doesn't lurch in 6th and just rolls to a stop. Happened while hauling the second load of manure down the road.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2011 at 8:25pm
Are you sure 5-6 are the only gears that don't pull in? Hold the brakes and shift from 1 through 6 see if some others are week.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2011 at 8:59pm
The next time you stick it in 5th or 6th and it stops moving, see if the power steering still works or not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DansXT Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2011 at 9:26pm
The power steering still works and other gears are fine. Could the A1 clutch set not be working since those two gears use that set and/or could the 6 bolts on clutch hub be broken too?
This page was generated in 0.079 seconds.
