Allis c rear light
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Topic: Allis c rear light
    Posted: 24 Oct 2011 at 9:00pm
Does anyone know where I can get parts to restore the rear light on my c. Lens and bulb socket.
Can't fix stupid
Blake_AllisMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blake_AllisMan Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2011 at 11:10am
I would maybe check ebay and see if they got anything. Im sure someone on this site has just what your looking for. Blake
1941 C
1952 IB
1947 C
1955 WD45 SFW
1956 WD45 Diesel
1977 5020 4WD Serial Number 1
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2011 at 11:28am
Witch lens or do you need both ?
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2011 at 11:55am
The rear " brake light" i guess is what it is. It is 3" in diameter.
Can't fix stupid
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2011 at 2:57pm
It's a work light. Should have a clear lense, if you're talking about the one directly over the PTO shield. If you have a little red bullet light on the fender, it's not original(to my knowledge). I would check on E-bay or one of the vendors that advertise on this site, like Tony or some of the other fine folks.
I didn't do it! It was a short, fat, tall, skinny guy that looked like me!
Bill (E.C.MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill (E.C.MO) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2011 at 3:25pm
AJ,
Which lens do you need?  A factory B/C tail light has two lenses:  a clear, disc shaped lens which is aimed back and down towards where an implement would be, and a red cylinder shaped lens that shines up and back through a window in the housing.
I don't believe either of these lenses is a stock item anywhere, and they are both hard to come by.  I hunted a long time for the red one and ended up using pieces of an old one glued together.
Norm---norm's toys Norm---used to have these assemblies but I believe he's sold out of them.  He might still have some parts?
Those tail lights are seldom found and always nice to see on a B or C.
A-C's currently on the farm: B, CA, 2 D-17 D's, One Eighty, ass't implements.
jccleav View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jccleav Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2011 at 9:21pm
I have been looking for the whole assy with no luck. I though I hag the bent up old housing that was on my B but can't find it. It must be with the brake cover that is MIA also.
The joy is in the journey.
AC "B" and "WD" and "C"
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2011 at 10:56pm
^ what Bill said.
I'm lucky, I've got mine, its always been intact, never broken, and 100% original. Haha. So far I think I'm the only one lucky enough to have this situation. I just need to get some "innards" for it and a bulb for it so it works.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2011 at 6:40am
So this light isn't a standard part?.... The 3" round lens is suppost to be clear and the little opening is suppose to be red? I was told by a guy I showed it to said that it was the other way around.
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2011 at 6:48am
 Yes it was a standard part but is no longer available. I believe at one time, someone was making a reproduction light that had the red round lens and the clear rectangle lens. It's too bad they didn't take the time to get it right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2011 at 7:08am
Tucker, I think you are talking about the early combine light ?
Edited by Fred in Pa - 26 Oct 2011 at 7:12am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill (E.C.MO) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2011 at 8:06am
This tail light was a "standard", factory part on most B's and C's.  I think some late models went to a bullet type tail light, maybe Ken in Texas, Bill Long or one of our 'B guys' could clarify on this.  At least one fellow on the forum has an in-the-box NOS tail light assembly and has posted pictures of it here before.
It's counterintuative, but the round lens (part #6 below) is definitely clear and the globe/cylinder lens (part 3)  is red.  A crafty guy with a heat gun, a strip of clear plastic and some red lens repair tape could probably fabricate a substitute red lens.
Edited by Bill (E.C.MO) - 26 Oct 2011 at 8:10am
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2011 at 8:51am
What was the point of having the red lens facing up? That just don't make sence to me. I would think the round lens would act as a brake/warning/safty light and the little rectagular would shine down at your draw bar area.
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote jccleav Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2011 at 9:38am
The round lens should point down to be able to see the implement and what you are doing. The red side lens should point back.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2011 at 9:42am
Everyone seems to adjust them to be perpendicular to the ground and that makes the white lens point back.  Notice the mounting bracket is not 90 degrees.  JC has it right, the red acutally points back (and up a little) and the white poins down (and back a little).
JimD
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2011 at 10:12am
Hi: I have a original white lens(still in the box no 70212763): I have a nice original lamp with white lens in with the red on the bottom,this also has the original mounting bracket and bost. I have a lamp with red lens,bottom one is broken out. May have other odds and ends. Will take offers. 785-353-2392
Murph-NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2011 at 11:40am
'41 C w/Woods L503 mower, #3 mower, 2-way plows for C
daveingreenbay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote daveingreenbay Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2011 at 12:18pm
Have a nos round red lense for one of these lights.
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2011 at 2:03pm
From a C Allis Owners book.
                                   TAIL LIGHT
The tail light is mounted on the rear seat frame angle for use as a tail light and also for vision if equiped with a white lense.
I think the key words here are ALSO and IF. But. Can you have it both ways?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2011 at 10:00pm
I've seen them with both a full red lens, and a white lens. We have a nice repro of the lamp equipped with the tailight type red lens and white half moon lens.
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2011 at 5:45am
Nope, see Steve's post on the reproduction light.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2011 at 6:22am
Steve@B&B   I have seen them both ways too.
 Exactly the point I was trying to make by reading  the C manual.  Aparently it was a user friendly option to have a clear lens lamp for vision or a red lens lamp for a tail light way back in the day.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2011 at 6:46am
Well that is good to know. I plan to restore the one I have and put it back on my allis c. Thanks everyone for the help. Aj
Can't fix stupid
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2011 at 9:37am
NOS
are genuine." - Mark Twain
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2011 at 2:48pm
Larry, you wanna add me to your Christmas gift list again? LOL
This page was generated in 0.085 seconds.
