tire and rim combination question
allis d14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis d14 Quote  Post ReplyReply Direct Link To This Post Topic: tire and rim combination question
    Posted: 19 Nov 2009 at 3:59pm
i have a 1957 allis chalmers d14 with rotted rims .it has 13.6x26 inch tires on it now  i found a line on some rims off a back hoe. they are 14.9x24 tire and the rim is 13x24. will these rim fit without hitting the final drive gear reduction housing bolt pattern and hub diameter are correct. and what would theses be worth tires about 25% worn and rims are not rotted.
chris
Edited by allis d14 - 19 Nov 2009 at 6:53pm
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2009 at 5:13pm
With 24's you will be driving up hill all the time.  Try and find a set of 28's. I put 28 on my D14 and they look fine.
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis d14 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2009 at 6:49pm
Edited by allis d14 - 19 Nov 2009 at 6:51pm
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2009 at 7:13pm
 A set of 16.9 x24's would look great, and would work OK on 13" rims tho 14 or 15 would be more better. Will the offset work for you ?  If you can get them reasonable , , maybe $300, or so , I'd go for it and sell the 14.9'a and look for 16.9's Those backhoe tires are prolly 10 or 12 ply which you don't need. Gary
I started out years ago with nothing.... after this divorce , I'll be getting most of it back.........
D15Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D15Man Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2009 at 12:53am
  Why not just use some 14.9 x 26s instead of changing the wheel size? If you go to 28s or 24s you're going to have a tractor that's too high or too low in the back. If you want to keep the Power-Shift wheels you'll need different wheels and rims and tires and all, not to mention the wheel lug patterns matching. I don't understand going to 24s because 24s have a 5 or 6-bolt lug pattern on the wheel, and are way undersized for a D14.
  14.9 x 26s are all the tire a D14 could ever want for farm work--they will hold a D15II very well, and a D15II is a heckuva lot more powerful than a D14! They may kiss the fenders when pulled all the way in, but the fenders can easily be raised. With 28s the fenders will hit the tires if the fenders aren't raised for Power-Shift wheels.
  If you're just looking for economy and don't care what the tractor looks like with bastard wheels, then go for it! I'm just making a suggestion. Good luck!
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2009 at 5:45am
 I repaired my D14 rim.  It is not that hard.  Richard
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2009 at 6:46am
Like R Aiken says, not hard to repair the original rims. I just repaired the valve stem areas on my D17. I just sliced out a couple sections on another wheel and welded them in on the originals. The first one turned out pretty good. If you know there is a patch there,  you can find it. The second one can't be seen at all. For cutting I used a cutoff wheel made for a Skill saw. If you're good with a torch, that would be easier.
Edited by Brian Jasper co. Ia - 20 Nov 2009 at 6:50am
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis d14 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2009 at 11:27am
the rim are totally rotted there is no repair. i just dont want to buy rims for an obsolete tire size which are the 26 inch tires
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2009 at 12:24pm
I think that they will work fine, and 14.9x24 is a size that will be around as some center pivot irrigation sprinklers use this size currently. Kip
This page was generated in 0.060 seconds.
