7020 pto
jjpetrich View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjpetrich Quote  Post ReplyReply Direct Link To This Post Topic: 7020 pto
    Posted: 06 Sep 2011 at 11:06pm
Back pto has a little play in it.  just wondering if its a bearing that was going out or could be a bigger problem.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2011 at 5:03am
Just a couple stupid questions, are all the bolts around the outside edge tight?  Where the flanges clean before bolting it up?  Define a little?  all shafts and bearings have a very small amount of play in them.  are we talking thousands, or tenths of inches of play, and which dirrection are you talking?  Up and down, or in and out?
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjpetrich Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2011 at 8:27am
bolts are all tight and everything is clean it moves about a 1/4 of an inch side to side
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2011 at 9:28pm
sure sounds like a bearing is out, or a really badly worn shaft.  It must be leaking oil too??  A 1/4" is way too much
Still in use:
