720 engine options?
plowboy8550 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plowboy8550 Quote  Post ReplyReply Direct Link To This Post Topic: 720 engine options?
    Posted: 04 Sep 2011 at 9:01am
My 720 has a bad carb and the cyl walls are scared so I need to repair or replace.. Small engine werehouse has a 23 hp briggs for 1800 but id rather have a little bigger engine and if possible a diesel. What have you guys seen or done?? Any ideas?
 Thanks Matt
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2011 at 9:37am
What model was the Honda engine people repowered with?That is what I want. Tracy Martin
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2011 at 12:21pm
I have both a 620 and 720 I want to repower, would like the honda although I have been told by the small engine people locally the Vangaurd engine is actually better and have had less problems with them than the honda, and as I understand it is either a copy or it is built in Japan, have thought about the diesel option but after looking and driving some small diesel lawn tractors, I am not going to pursue it they shake to much, are noisy and small diesels do not perform like there gas counterparts. So it looks like its going to be the Vanguard for me would be neat to do a honda and a vanguard just to see which one is better.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2011 at 12:33pm
the small diesel in my AC 920 is powerful!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2011 at 12:39pm
how many cylinders? shake? noise? make? I am still curious about the diesel but like I said the ones I have seen dont turn my crank ......yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2011 at 12:46pm
KC...it's a "lambordini" engine, came from the factory that way. and i'd hafta look as to how many cyl's, i can't remember right now. either 2 or 3 i think! i'll let ya know!l. and parts are readily available on this engine! even in omaha,ne!
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2011 at 12:46pm
look on eBay, there is often a Honda Repower kit available for the 620/720 engines.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2011 at 12:48pm
sorry..i hit the button before answering the rest of your ??'s...has a shake upon startup, then smoothes out, is very quiet ( has a short muffler) , my wife drives it, she loves it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2011 at 12:48pm
air cooled water cooled I heard if you put the diesel water cooled in you have to put them in with the radiator in back is that how your is?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2011 at 12:49pm
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2011 at 12:49pm
I used the V Honda to replace the K341 Kohler 16 HP in my New Holland S16.
Same engine in Honda is rated from 18 to 27 HP , so unsure of what they change in it to up the HP. Might get some ideas from this link
Another link to 720 repower
Edited by Coke-in-MN - 04 Sep 2011 at 12:53pm
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2011 at 12:50pm
If I recall correctly, Lombardini is connected to Kohler. They use those diesels on walk behind tractors and they seem to be good little engines. The walk behind engines are air cooled. I don't know about the larger ones.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2011 at 12:52pm
mines air cooled, i have seen ones with radiators hanging on back, i wouldn't think that would be a good thing! i have also seen kabota liquid cooled engines on AC garden tractors!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2011 at 12:53pm
yeah..wjohn spelled it right!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2011 at 12:54pm
grasshopper mowers also use the kabota diesels in them!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2011 at 12:57pm
Dang you guys now I got to rethink this again!!!!!!!!!!!!! Although with 2 could make one diesel and one gas, the 620 came with a tall ag tire should put the diesel in that one w dual on, now that would be wicked
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2011 at 12:59pm
At one time I was thinking of putting a Kubota 3 cyl gas engine in my 720.
35WC on steel, B with belly mower, D17 puller, D15 Series II puller, D15 Series II with loader, 608 Lawn Tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote plowboy8550 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2011 at 1:08pm
I was told that the new hondas use a positive ground now, thats why you dont see them in the conv kits anymore..  Im just thinking that about 30 hp would be ideal and turn it into a mowing machine.. Its hard to tell what hp ive got now but i would guess around 10 so anything will be a drastic improvement.. When you mow with a very weak engine and have to go so slow you cant help but daydream about going 7mph cutting grass. :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2011 at 1:12pm
Seen the small V Honda engines used in cycles and are said to be putting out 45+ HP with some small modifications.
 As far as polarity of charging system that is a small problem that isn't a problem . All my British motorcycles are + ground.
Dale H. ECIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale H. ECIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2011 at 9:06pm
I put the Honda 24HP replacement from Small Engine Warehouse 4 or 5 years ago in my 620 and have not regretted it one bit. It has not used a drop of oil and uses at least 1/2 the gas as the Onan engine. It has more power than the Onan and the deck belts will slip before the engine pulls down.
Allis Chalmers Museum, Paris, Il.http:// www.allischalmersmuseum.com 217-275-3428
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2011 at 8:40am
those Lombardini engines are 2 cylinder in the 920. Lombardini and Briggs&Stratton were somehow tied together.
This page was generated in 0.952 seconds.
