My D17 Series II
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: My D17 Series II
    Posted: 21 Aug 2011 at 6:26pm
I keep asking a lot of question on her so I decided to snap some photos to show you what I have.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2011 at 7:09pm
Nice straight looking tractor. If I read it right, you have what is known as a late series 2. Early series 2 had a black bar grille with silver mesh, the D17 decal on the side sheets you're missing, and silver "ALLIS-CHALMERS" lettering on the hood.
It's a kinda complicated to sort out all the changes in the D17 over the 10 years or so they built them.
Yours probably had a corn picker on it judging by the screen on the air stack.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2011 at 7:13pm
Nice straight tractor, I've always been partial to the narrow front too.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2011 at 8:42pm
Looks really good!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2011 at 8:48pm
I have one just like it.Love the NF.Never had one in the past but quickly am becoming a convert.Turns easier and looks better.Tires look OK, fly wheel base minus pulley is a plus,How much? I paid 1700 and your tires are better.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2011 at 8:57pm
Brian,
I believe the "black Bar" D-17 was referred to as the black bar Series I and still retained the Persion Orange color including the rear wheel centers and front wheels.
The Series II  was painted Persion Orange #2 with cream colored rear wheel centers, front wheels and grill (with no bars).
You're right, the D-17 model designations can be a bit confusing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2011 at 9:03pm
front tires are shot, just need to save more to get a set.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2011 at 9:08pm
BTW, Charlie, Your D-17 looks really good with all that nice straight sheet metal.
I have a '61 Series II (WFE) Ser.# 34633 but she doesn't look anywhere near as nice as yours as it had been rolled once by the P.O. and the sheet metal (including the gas tank) is in pretty rough shape. The D-17 sure was a "step up" from my WD and WD-45s.
Just curious; do you have the factory snap-coupler 3PH adaptor for your tractor?
I see you have the toplink bracket and what "might be" a factory top link with the hand wheel broken off.
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2011 at 10:19pm
Brian G. I believe you are correct on the series I and II differences.  The bar grill were just a late series one.  Series II debuted in 1960 with the PO2 and creme wheels.  Very nice looking D-17 by the way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2011 at 5:18am
Brian, I did get the 3 Pt adapter with the tractor, I have no idea if the top link is OEM or not. Not sure if you can tell but someone cut two holes in the seat bracket to mount a Top link there, I guess they required a higher hooking location.
I am amazed at the power it has. I compare it to Dad's D15 and 10 HP makes a huge difference. It will pull 4 high on any hill I have tried but it does seem lower geared than the 15.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2011 at 5:26am
I am still in need of help with the front pedestal shimmy. I replaced the lower bearing and seal which were shot, made sure the coupler matched the lower and upper shafts and had no play, but I have slack in the gear mesh in the power steering unit. I checked the gears for wear when I had it apart and I did not see any wear. If I have the front lifted up I can rotate the wheels side to side maybe 1/2 inch each way from center before it catches. Can the Ram shaft be adjusted in to take up slack? As this is where it seems the slack is. The steering worm gear and the main gear snicked up tight when I put it together.
Charlie
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2011 at 5:29am
You have an OEM top link for the 3 pt adaptor but the cast adjusting wheel has been broken off.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2011 at 6:55am
Another thing new for the 1962 Series II is the thumb guard on the power director.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2011 at 6:57am
The seat in the photo shows a pan seat.  Our 1962 series II D-17 came with a two piece seat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2011 at 8:48am
That appears to be the factory top link bracket for the Series I, II & III D-17.
BTW, the reason they call it a "Bracket for P.T.O."  is that the other version of the 3PH adaptor places the top link bracket on a bar between the lower arms which precludes the use of PTO powered equipment but does allow full use of the traction booster feature.
Edited by Brian G. NY - 22 Aug 2011 at 8:54am
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2011 at 9:01am
Charlie, on the power steering rack on the right side of the bolster underneath the cowling sheetmetal there is a plate about 4 inches square with 4 flathead bolts in it. If you take that plate off you can remove some of the shims to bring the rack up tighter to the gear if that will help. HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2011 at 10:04am
I will try that next, thanks
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2011 at 2:19pm
Boy, I wish my WD had one of them "magic" plates!  LOL
VerneM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VerneM Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2011 at 7:45pm
Overall, that's a fine looking D17. All the panels look to be in good shape. A little elbow grease and it should look like new in no time. How's the engine running on it?
Verne - Looking for a teejet sprayer for my tractor
PBSoMd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PBSoMd Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2011 at 7:58pm
Charlie
For some reason it looks alot better in your back yard then it did in ours! Looking good!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2011 at 6:04am
Does anyone know where I can get the center handwheel replacement for the top link?
Verne, yes it does run pretty good although I have nothing to at my house that will test it. I'm pulling in the 5,000lb class tonight so I will get to see how much umph it has.
PB, it does doesn't it! :)
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2011 at 8:33am
Charlie,
Those handwheel top links come up now and again on e-bay.
I won't mention what they bring, it could cause "heart palpitations".  LOL
I hope you post some pics of you at the pull!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2011 at 10:01am
If might run my helmet camera, just need to find a way to mount it.
Hmmm, high dollar piece is it? I will search around. Can't imagine how someone broke it off.
Charlie
PJsomd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PJsomd Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2011 at 9:46pm
sounds like its coming along charlie like to see some pics with it hooked up to the sled good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2011 at 7:14am
Got there late, the pull order was not the same as posted on the web at sign up and we were up first so I had to run around unloading and didn't get to take any pictures.
Track was tight, I elected to pull 1st gear which it hummed along OK in, only pulled back to low at the end and it was still powering through it as I spun out. 2nd would have been to much though. Last 10' I hit the same spot as many of the previous pullers and it pulled hard right to the line. I guess I made a bad line choice. Front danced a little as I only had my B rear weights on the back. Weighed in at 4700
I forgot to lower my PSI as my dad said the rears never buckled so I am sure that would have helped. Right wheel slipped on the ecentrics and tucked all the way so I need to take them off and get them freed up.
It was funny as the announcer keep saying "now this is a great STOCK tractor and wished there were more of them".
Pulled against:
WD45 with 301 Diesel (Winner)
JD A (Hopped up)
JD A (unstyled) (Hopped up)
WD-45 (I think this had a E also)
Farmall M (it lopped along until it hit load and wow it had HP)
WD-45 (Gleaner E)
Farmall Super M
Ford 4000 Diesel with Turbo
Ford 5000 Diesel with Turbo
WD-45 (stock)
Edited by Charlie175 - 24 Aug 2011 at 7:17am
Charlie
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2011 at 1:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2011 at 7:38pm
wow, they are pricey
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2011 at 9:49pm
No bids on this one yet.
I saw one sell for $266.53 and another for $300 even.
It really could give you heart palpitations!!  LOL
This page was generated in 0.184 seconds.
