Model B horsepower & carb question
waynem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote waynem Quote  Post ReplyReply Direct Link To This Post Topic: Model B horsepower & carb question
    Posted: 13 Aug 2011 at 5:44pm
This is my first tractor a 1940 Model B. I would like to order a carb kit it is a Zenith carb where do I find the carb numbers so I can order the correct kit? 2nd question I have been reading that there are 2 different horsepower ratings I think  39hp & a 20hp how do I find out the hp rating? As always everyone is so helpful to me because I am so new to this stuff thanks in advance.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2011 at 5:49pm
The hp would be more like 15 and 20 and yours would be 15 because it's the BE motor instead of CE. There is a round tag on the top surface of the carb toward the engine with the model # on it.
steigerbro24 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steigerbro24 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2011 at 6:29pm
What do you mean by a BE engine? My B is a 1944 model.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2011 at 6:32pm
A 1944 would have a CE motor. The BE is 116 c.i. and the CE is 125 c.i. 1943 was the year they changed, all the C's and CA's had CE motors.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2011 at 6:39pm
Wayne M,  First Congratulations on obtaining my favorite AC unit, the B.  Listen closely to what is said above.  They are accurate.  If you need a Carb. kit you can contact any of the sponsor's of this site and they will be glad to help.
Let us know if there is any further assistance needed.
Take good care of my favorite.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote waynem Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2011 at 6:49pm
Thank you every one.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2011 at 6:53pm
  we all the carb kits for zenith carbs   1-800-254-3116  we ship us mail
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2011 at 8:35pm
Welcome to the forum.
 There is really no way of knowing what internals are in your engine without checking bore size. It more than likely was overhauled at some time in it's life and could say BE on the block but have 125 cubic inches.
 Take it to a tractor show and belt her up to a dyno.
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2011 at 9:55pm
CTuck is correct. Standard 3 3/8 liners and 3 7/16 overbore liners and pistons will slip right into a BE engine block. If you can't find the BE engine block SN in the left hand engine flange look on the back of the block right near the top below the head.
   If you suspect a engine swap was made a rule of thumb is. A 38 B block casting number should end in a 9 or a 10. A 39 B block casting number should end in a 11. 40 a 12. 41 a 13 and so on. This pattern seems to hold true on Bs and Cs up thru the 40s. Some tractors produced early in any year may have engine block casting codes from the previous year.
   Most heads have a actual casting date in raised numbers in the bottom of the oil galley.
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2011 at 7:25am
Most kits being sold are pretty much worthless.
They have a new needle valve and seat with a new gasket.
Someone is selling a better kit.
I bought one years ago from a person but I can't remember who it was.
His kit had alot more new parts along with 2 new shafts with brass shaft bushings and shaft seals.
Someone on here might know who he is.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2011 at 9:15am
The BE had 3 1/4" pistons, The CE had 3 3/8" pistons. The only difference in the two engines was the pistons as far as HP. You will not find one out of ten BE engines that still have the 3/1/4" pistons still if that many. The low compression BE engines had either dished piston tops or a flat top that was shorter but still 3 1/4"
Some engines with 3 3/8" pistons had pistons in them that did not come all the way to the top of the block/deck.
After 70 years the only way to tell for sure is to remove the head and measure. You might be surprised as to what you would find.
Most carburetor problems are dirt. Dirt that can not always be seen with your eyes.
Spray can carburetor cleaner is good for cleaning your hands and the outside of the carburetor not the inside of a carburetor. Consumer protection dontchyaknow!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2011 at 10:12am
Right you are.
You have to manually remove the dirt and that is easier said than done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote waynem Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2011 at 10:47am
Thanks to all for the info. I found the engine numbers on the back of the block they are BE2754 Is this the correct engine in there or a replacement?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2011 at 12:17pm
We have carb kits in stock. Also offer carb rebuilding services if interested...
Steve@B&B                customcircuits@gmail.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2011 at 1:43pm
waynem
     If the BE engine number is that low and on the back, it probably came new in a 38B. Check the casting numbers (The raised numbers cast on the Left side of the block) and see if  the last 2 numbers are  1 0.  The early block would not have the tapped holes for a generator bracket on the front left side. Most if not all the blocks cast in 1940 had the holes tapped for genny mounting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2011 at 6:37pm
That engine is out of a 38 B. What is the tractor number stamped by the shifter? Do you know for a fact the tractor is a 1940? That would put your tractor number between   B33502 and B49720. It is not uncommon after 70 years to find a tractor with an engine out of another tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote waynem Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2011 at 7:32am
Ken & CTucker the BE # is BE2754 the # on the left side of the engine AM-2916-10 the tractor # is B41011 the carb # is206989 on the outside & 8561 on the inside according to Jeff Z he says that carb was used in 1938 & 1939 aby more info would be helpful.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2011 at 7:41am
From my records that casting # ending in 10 would make the engine a 1938.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2011 at 12:09pm
The Transmission is a 1940. Does it have a electric starter? Most 40s do. How is the generator bolted on. I ask because special brackets have to be fabricated to mount a generator on a tractor with a 38 B engine, which is what you have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2011 at 12:26pm
Tall Spindle adjustable front axles became available in 1940. Most if not all 40s with this axle also had 5 stud adapter hubs and 5 hole semi-dish reversable rear wheels.
Is your 40 equiped this way?
Post Options Post Options   Thanks (0) Thanks(0)   Quote waynem Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2011 at 8:33pm
No my 1940 is not equipped like that I have no starter or generator or battery box & my rear tires do not have 5 bolt hubs like that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2011 at 9:05pm
You may have a 38 or a early 39  tractor with a 1940 transmission swaped in . Do you have a water temp gauge? 38 Bs did not have one. There is no hole near the front of the hood behind the radiator cap for one. The notches in the rear wheels for the valve stem? Are they V shaped or like a half moon. 38s are half moon shape notches. Are the front wheels 5 hole automotive style? 1940.  Are the hubs rivited to the wheel centers? late 38 and all 39s. Are the front wheels with hubs a one piece of cast iron with a steel rim? Early 39. Posting  some pictures would help. It must have handbrakes too I bet.
    Could be a 38 front half with a 40 rear half. We will figure it out soon.      Ken
    Someone may have built your B out of good parts from several Bs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2011 at 9:55pm
I guess it really doesn't matter much as long as it runs.
Remember "One Piece At A Time"
Post Options Post Options   Thanks (0) Thanks(0)   Quote waynem Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2011 at 7:32am
Thanks I will check all these things out after work. I will also have to figure out how to post pictures.
Post Options Post Options   Thanks (0) Thanks(0)   Quote waynem Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2011 at 7:34am
Yes it has hand brakes also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote waynem Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2011 at 7:35am
Also it has a temp gauge  which does not work 1 more thing to figure out.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2011 at 8:25am
they are cheap enough to replace. Hopefully is has not corroded/rusted itself to the mount.
Charlie
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2011 at 8:59am
Not sure that Jeff is thinking of us, but I have been very happy with our kits.  Here's a photo of one sprawled out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote waynem Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2011 at 8:26am
Post Options Post Options   Thanks (0) Thanks(0)   Quote waynem Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2011 at 8:27am
I will get better pictures later I am taking it to work to show off. I will also figure out posting pictures better.
This page was generated in 0.114 seconds.
