Live Hydraulics 1941 WC ?
Ductking1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ductking1 Quote  Post ReplyReply Direct Link To This Post Topic: Live Hydraulics 1941 WC ?
    Posted: 03 Aug 2011 at 11:27am
I just bought a 1941 Allis Chalmers WC and am looking for any help on buying and installing a pump for live hydraulics. I would like to put a small bucket loader on this tractor. I have a picture of a WC with a pump and hoses mounted on the right side and a belt coming from the pulley that would run a hammer mill, etc. I was wondering if anything may be available that would run off the PTO. This is only the second tractor I have owned, and am not very knowledgeable. Any help would be greatly appreciated.
Thanks, Ken
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 11:31am
For a live hydraulic you would have to attach the pump directly to the engine.  Anything attached to the belt pulley or PTO is behind the clutch and would be affected by the clutch.
I have heard of it being done and in fact, I think there are some pictures on this site some time ago that worked it.
Perhaps others more knowledgeable than I on this can chime in.
Good Luck!
Bill Long
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 11:33am
Niether the belt pulley or PTO are live. to get livve hydraulics you need to mount the pump to the engine driven by the crank pulley.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ductking1 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 1:00pm
I see what you mean. Maybe I am thinking wrong. I am just looking for some sort of hydraulics in order to run a loader bucket and or plow blade I guess I would have to use the clutch and then the tractor would go into neutral. Maybe off the front where the hand crank is ?
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 1:13pm
one easy way is to have a "charlynn" pump mounted to the Pto.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 1:17pm
Matt, he said he wanted LIVE hydraulics. It would have to be a front mount driven from the crank or a side mount belt driven pump. I have seen power steering pumps mounted off to the side like the generator and use the transmission for an extra reservoir.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 1:50pm
Read his post above mine, He is looking for any type of hydraulics. I am just giving an example.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ductking1 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 2:20pm
I was thinking for the PTO I may mount a winch to skid logs. Everyone needs a good winch. If I can figure this loader deal out. This will be a good tractor for around my property.
pumpkinman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkinman Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 2:44pm
Fred in Pa had a w c  with a front pump & loader for sale was going to part out 2 weeks ago may still have it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ductking1 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 2:53pm
I'm new here. How would I get in touch with Fred. I am in Trout Run, Pa.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkinman Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 2:56pm
freds ph # 717-451-6590
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ductking1 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 2:57pm
A picture from classifides with hydraulic pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ductking1 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 3:28pm
Called Fred, he sold it. Just my luck. Sounds like just what I am looking for.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ductking1 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 4:24pm
My Allis
G226WD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote G226WD Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 4:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ductking1 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 4:41pm
NICE
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ductking1 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 4:59pm
A bigger picture of my Allis
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 5:13pm
Maybe like this WD setup
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ductking1 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 5:55pm
Looks like it would work. I have to get some more education so I know what I am doing. I am going to buy a manual for my WC this week. Thanks for the info.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 6:05pm
I took this picture at the GOTO in Tulare CA.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ductking1 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 6:16pm
Thats a rigging.
acwdwcman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 6:41pm
if i was you i would buy a wd or wd45 with a loader.. it would be alot easier. and you can get them for under a $1,000...  but thats just my 2 cents..
wd with a freeman model 90 trip loader, wd45, 38 unstylled wc, b 10 garden tractor and 2-14 ac trip plow. grandpa has a 56 wd45. wd. allis chalmers snap coupler blade and 3 bottom snap coupler plow
This page was generated in 1.064 seconds.
