6080 or 185
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Topic: 6080 or 185
    Posted: 01 Aug 2011 at 11:24pm
What would you choose? Thinking about getting something a little bigger than the 175D for some of the brushhogging jobs I do...worked the crap out of the 175 today on 8' tall swamp grass.....maybe a stripped down 190XT would be better?? Tractor and mower need to stay under 10k in weight for hauling.....
ALLIS EXPRESS!
This year:
singingpig View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote singingpig Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 12:08am
Instead of a different tractor, I'd goto a different mower. A flail would mulch that swamp grass fast, and you could use a wider mower, finish faster
Tractordata shows the 175D at 62 HP, same as my FOrd. Have no problem with a 9 foot flail on my Ford
Edited by singingpig - 02 Aug 2011 at 12:11am
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 5:21am
6080 would be my choice, more gear choices, live PTO
Charlie
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 7:23am
6080, you would have more power, and probably be better on fuel.  Nothing wrong with a 185 though either.  I have a 180  at 80 hp and love it, its very good on fuel also.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 7:58am
190xt is about 8,000, how much dose your mower weigh?
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 9:49am
you could get into a 185  cheaper than a 6080, although a 6080 has more gears and independent PTO.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 10:19am
I think the 6080 weighs less than the 185.  The turbo 4 cylinder has excellent fuel economy (and power - mine dynos over 100).  You also get live PTO, fully synchronized transmission and a faster road gear than the 185.  One thing you might need is front weights.
BStone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BStone Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 12:58pm
I have a 185 and it's been great.Have a 6060 and it's also been great.I had 2 185's and sold one for $4350.Down in Tx there hard to sell.They ask 3 to 4 thousand $'s more for the 6080's but they are newer and nicer...synchronized trans. and user friendly PTO's.
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 2:27pm
Besides a lower price, the 185 gives you the power director and its wet clutch.  That can be quite useful at times.
Mark
GTH-L Simplicity
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 3:16pm
Hate to say it Eldon but you had the perfect 185 in the palm of your hand.
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 3:30pm
Shucks, Eldon....get one of each and then report back on which you like better. :)
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 3:32pm
Dave - that's the BEST advice yet...Eldon's not been known to be stingy about adding to the collection!!!  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 4:30pm
I vote for the 185 ;  I have both and will take the 185 any day - the 6080 has more speeds but the gear speed between intermediate  and hi is terrible ; you have to keep the engine above 1800 rpm,s to get anything out of it , its helpless as a loader tractor - will spin out in grass and thats with an AC loader with a 4 ft bucket and loaded 18.4-34 in. rubber and wheel weights; they are not balanced at all , spins out  easily with 2 ton of feed in a grinder mixer  ; I just dont like it at all ; now the 185 is great , the powerdirector is so smooth , its easy to change transmission gears with the PD in neutral without grinding , the 301 engine will run great at any rpm  , with power and not just smoke ,put 34,s or 38,s on it and you have fast road gear , the hyd. pto is great !!!  IMO the 185 is twice the tractor over a 6080, but thats me
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 4:58pm
No since in stripping down the 190xt, if you are going to own one, might as well have all of "XT"
1968 D15D,1962 D19D
skateboarder68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skateboarder68 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 7:03pm
We have both, the 185 with the 301 starts very easy and has more torque.  It isn't the best mower tractor cause when you want to stop you either have to disengage the pto or put the PD in neutral.  As for the 6080, a brand new tractor would be no better on a mower, GREAT fuel economy, live pto, shift on the fly, turn on a dime.  Both have good road gears - our 185 & 6080 both have 18.4X34's and the 185 goes 1 -2 mph faster.  Both very good tractors, good luck Eldon!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 8:39pm
Nice 185 on tractor house. Little TLC and it would be ready
http://www.tractorhouse.com/listingsdetail/detail.aspx?OHID=6381097&
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 8:43pm
I like this one, kick off the cab and lose the duals. 2200 hrs.
http://www.tractorhouse.com/listingsdetail/detail.aspx?OHID=6216683&
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 9:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 9:39pm
I think you may be exagerrating a bit on the 6080, 185's are an awesome tractor but the 6080's are good also. They are two different animals though. I've ran both and IMO the 6080 is a more user friendly tractor. Not better, just more user friendly. I dont agree with the comment about the 6080 being a bad loader tractor at all.
EricTn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricTn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 9:49pm
I like my 185 except for the speed selection is limited. Either way too slow or a little too fast. Best I remember 1st high range is 2.6 mph, 2nd low range jumps to 4.1 mph (per shift pattern chart on tractor). Nothing in between in the 3 mph range, which seems to be what I need in most situations bushhogging especially in unknown territory. JMHO Eric in TN
HARVESTMOONPULLER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HARVESTMOONPULLER Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 10:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 10:50pm
I'm kind of afraid this type of grass would want to wrap up on a flail....anyone have that problem?
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 10:53pm
Mower is around 1800# so a stripped down one might work...I might burn up the slip clutch with the 190, tho...guess I should try the one I have. It has a cab and weights, I think it is closer to 10k
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 10:56pm
Seems odd the Perkins 248cid in my 175D is rated at 62hp but the 6080 200cid can get that much more with a turbo......
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 11:12pm
Yeah that was a beauty. Low hours and perfect condition....oh well....probably bought 10 tractors for what I sold it for, tho!
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 11:13pm
Dave I would like to....but since Robin quit her job to work on the farm my funds have dried up....aaah, the good ole days!
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 11:15pm
Originally posted by HARVESTMOONPULLER HARVESTMOONPULLER wrote:
Heres one for ya.
I like that one, too bad it is so far away!
ALLIS EXPRESS!
This year:
kffischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kffischer Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 12:24am
disc mower would be another option. three point and pull behind models are available and the smaller ones don't require much power--your 170 would pull a small one. Don't get one with conditioner, then the power requirements come up and you may as well make hay.  We have a discbine (with conditioner) for our haying and it will take 5 or 6 foot tall grass without complaint and it can cut through small trees and shrubs if you need to or don't maneuver out of the way just right...
karl f
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 1:32am
I'd give the one-ninety XT a whirl. I just came in from baling with mine, and I love it. I know you wouldn't have any shortage of power, and fuel economy is awesome. I'm pretty sure that you are pretty handy with the PD, so lack of true live PTO shouldn't be an issue, either. Darrel
ky wonder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ky wonder Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 5:22pm
back the end of june i pulled a 10" woods in thick crep hevily infested withand 8' johnson grass with my 6060, and it handled the job easily, it would pull it in 2nd high but the ground was a little rough so i used it in 1st high, never gave a problem
i like old tractors of all colors
This page was generated in 0.104 seconds.
