Question on CE motor bearings
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Topic: Question on CE motor bearings
    Posted: 15 Jul 2011 at 6:30pm
Putting the CE motor together for my C and the book calls for shims between the bearing caps on the rods and mains but this motor didn't have any when I tore it apart. I woluld guess they were removed to tighten up the old bearings. So where do I get new shims from?
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2011 at 6:36pm
NAPA has them but brace yourself......40.00 for the kit that has just enough, no extras.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2011 at 6:41pm
Lonnie sponsers of this site -- also Bruces brother has them
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2011 at 7:03pm
We've got them.  $20 for a kit for all the rods, and $20 for a kit for all the mains.
JImD
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2011 at 7:03pm
If your engine did not have any, maybe you don't need them. The block might have been line -bored to accept the bearing shells without shimming. Just a thought.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2011 at 7:30pm
Gary is right; whenever I bring a CE engine in for machine work I have the bearings line bored and a bearing type pilot installed. Plastigage the bearings W/O shims; you should have 0.002-0.004 gap (I plastigage the bearings 180 degrees apart on the sides). If you need the shims; Jim D ia a great source.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2011 at 8:16pm
If you put new bearings in a rod and cap that needs shimmed, you will crush the bearing and have to replace it. Put the caps on the rods and the mains and mic the ID's and compare sizes to original specs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2011 at 8:30pm
You better start as Tucker said. Measure the crank to see what the journals are, and if they are round.. then measure the old bearing bolted into the rod, see what the reading is and if it is round. YOu want about 2-3 thousands clearance, and round. Mains are the same, they had shims when new, but either taken out to tighten a worn crank, or it was line bored and dont need it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2011 at 8:48pm
The mains on my WC didn't have shims but the mic told me it needed about .008 to get real close. The measurements were taken 12-6, 2-8 and 4-10 O'clock with no burrs, shims or bearings.  Things weren't quite round so I shimmed the caps .006 and carefully honed the ID, with a good set of Sunnen hones. My main bores came out 95% clean up at the OEM size. The caps had less than an 1/8 inch of non clean up at the parting line. When I put the .020 under bearings in and dropped the .020 under crank in, I had .0025 clearance and the crank spun free.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2011 at 8:52pm
The crank was ground .020 and I have all new bearings but it was not line bored, at least not this time. Tomorrow when I get home I'll do more investigating. In theory it should still need shims if it has never been lined bored I would think. Thanks for all the input, I'll update when I find out more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2011 at 1:01pm
I plastigaged it and with just snugging them up I was at .001 so if it was torqued it would be tighter than frogs but. I ordered shims. Thanks guys.
