WD water manifold |
Post Reply ![]() |
Jordan(OH) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Celina, OH Points: 1567 |
![]() ![]() ![]() ![]() ![]() Posted: 15 Jul 2011 at 7:33am |
My water manifold on WD is cracked. Can I replace it with a D17 style?
Steve M C/IL ![]() Orange Level ![]() Joined: 01 Jul 2010 Location: shelbyville IL Points: 691 |
My WD has the 2-port manifold.45/17's just use front hole.Don't know why you couldn't.Water neck might be a little different angle?
Orange Blood ![]() Orange Level ![]() ![]() Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
I think they will fit, my only concern would be to leave out the thermostat on the D17 manfold, and I don't know about hot spots in the head, since the GPM of the old WD pump is probably not that of the D17 pump. But without the thermostat, I am thinking you will be fine. If you are not running heavy loads on it you will be fine, but if you are I would be concerned about the back two holes getting warmer than the front two, since without the extra GPM, there is really no reason for the water to circulate back there. somebody else will chime in, to tell you I am over cautious, or just blast me, I am sure!! :-)
Still in use:
HD7 WC C CA WD 2-WD45 WD45LP WD45D D14 3-D17 D17LP 2-D19D D19LP 190XTD 190XTLP 720 D21 220 7020 7030 7040 7045 3-7060 Projects: 3-U UC 2-G 2-B 2-C CA 7-WC RC WDLP WF D14 D21 210 7045 N7 |
bump
Post Reply ![]() |
