Final drives pan gasket/RTV?
CB-Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CB-Man Quote  Post ReplyReply Direct Link To This Post Topic: Final drives pan gasket/RTV?
    Posted: 25 Jun 2011 at 12:00pm
When draining the final drives i think the manual says there is a cork gasket in there.  Is it best to get a replacement gasket or just use RTV sealant?
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 12:15pm
I use new cork gaskets; readily available at your AGCO dealer (or Sandy Lake Implement/Dean Ag). Use a non hardning sealer (RTV) on the pan side then you are ready to change the fluid next time.
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 12:20pm
Either or. They both work.
Your choice.
If you use RTV put a good bead on so when the pan is bolted up it spreads even with no voids.
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2011 at 1:33pm
Another RTV trick is to barely tighten the bolts with you fingers. Just enough to spread the sealant. Then the next day after it has cured do the final torque. That way you will be able to put pressure on the form in place gasket. If you torque up right away the seal will depend on adhesion only.
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2011 at 7:09am
I have started using the grey RTV and the instructions is to finger tight , then 1 hour later tighten. My problem is to comeback 1 hour later. My memory is not the best.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2011 at 8:18am
Don't worry about the hour, next day is better anyhow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CB-Man Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2011 at 10:02am
Thanks for the tips guys,  I wanted to get this done this weekend and really didnt want to order a pan gasket.  I will get some grey RTV and do what you mentioned.
Thanks alot
Brian
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2011 at 10:22am
In my VW manual where a lot came from the factory with RTV beaded in place they note a common detail. Always pass a bolt hole with the bead on the oil side of the surface, not outside the bolt, else the bolt will leak.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2011 at 10:26am
So that's why my neck is always wet.
The bolts in my neck are leaking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CB-Man Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2011 at 11:53am
That is true.  I worked as a mechanic in dealerships for 4-6 years.  When ever I do differential covers I always lay the bead to the inside oil side then go back and make a full circle around the bolt.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2011 at 10:57pm
I used Permatex 81182 Gear Oil RTV sealant on the finals of my WD last summer, got it from NAPA. I would suggest going that route as it gives you a positive seal compared to dry cork, and as little as you change gear oil anyway it's not that big a deal to disassemble.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2011 at 7:14am
I like the RTV system also, the cork wasn't that great to start with
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2011 at 7:48am
Laying out the bead on the surface and then smooth it out well so there is a thin even film, then wait about 15 to 20 minutes for it to skin but not full cure , this has worked well for me .
 Seems a lot of users run a bead like they are calking a window then tighten it up which makes a mess as the excess fallis into sealed area and migrates into fluid and bearings.
Faith isn't a jump in the dark. It is a walk in the light. Faith is not guessing; it is knowing something.
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2011 at 8:32am
You have to use common sense on the size of the bead. If you spread it out too thin then when it is compressed sometimes it leaves a void.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2011 at 8:43am
This is also a good choice.
http://www.permatex.com/products/automotive/automotive_gasketing/gasket_makers/auto_permatex_ultra_black_maximum_oil_resistance_rtv_silicone_gasket_maker.htm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2011 at 8:45am
http://www.amazon.com/Permatex-82180-Maximum-Resistance-Silicone/dp/tech-data/B0002UEN1U
Tripp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tripp Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2011 at 8:45am
Black RVT Silicone gaqsket maker.
