Info on 5030?
Wendell(OK/TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wendell(OK/TX) Quote  Post ReplyReply Direct Link To This Post Topic: Info on 5030?
    Posted: 20 Jun 2011 at 2:35pm
Brother wants me to look at a 5030 with loader with him this evening.   My fault, I gave him the phone number of it.  What are the pro/cons of these tractors?  What do we need to pay attention to and to run from?   Thanks
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2011 at 3:04pm
Was a great little tractor when new. Today Cons are hard to get parts and prices are high! Most internal parts aren't available from Agco or original maker of them any longer. Raise front wheels off the ground and check wheel brgs and axle pivot bushings etc. If 4wd and I hope it is! check king pins, seals any signs of leaking around outer final drives, and see how much backlash is in gears of 4wd. Any noises rough sounding brgs in front axle. Check motor for any signs of overheating and any signs of head gkt. leaking. As none of the these Japanese engines can stand being overheated to many times.
