WD Handclutch
Mike56073 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike56073 Quote  Post ReplyReply Direct Link To This Post Topic: WD Handclutch
    Posted: 14 Jun 2011 at 11:03am
  I've got a WD that I split awhile back to replace the bronze handclutch yoke, now when I release the handclutch lever, the lever falls all the way forward and something grinds inside.  I've had a few of these tractors apart, but obviously I overlooked something on this one.  Any ideas?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2011 at 10:07pm
If I remember right the pins that sets in the forks are not centered, so if pins are to the front the lever will lay farther forward.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike56073 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2011 at 8:24am
Anybody ever had any luck replacing the yoke without splitting the tractor?
dudley wallace View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dudley wallace Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2011 at 9:42am
mike check the snap ring on the input shaft if it is not on there it will let the hand clutch pack to travel to far forward and will try to engage the clutch or make a grinding noise maybe this will help dudley.
a member of hendricks county antique tractor and machinery association club.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2011 at 9:55am
You can replace the yoke without splitting the tractor,   what dudley says makes sense too, check the end play on the clutch assy by moveing the lever with the cover off.  HTH
This page was generated in 0.359 seconds.
