Allis Chalmers C Help!!
Blake_AllisMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blake_AllisMan Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers C Help!!
    Posted: 01 Jun 2011 at 4:59pm
I am disassembling the wheels on my Allis Chalmers C and the wedges that hold the hub and the rim together have two eccentric bolts on each pair of wheels. My question is where would a guy get eccentric bolts that fit into the wedge castings and where could a guy get some wedge castings that have the eccentric holes? Thank You very much for any information! Blake
1941 C
1952 IB
1947 C
1955 WD45 SFW
1956 WD45 Diesel
1977 5020 4WD Serial Number 1
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 5:20pm
Your tractor should on ly have 2 per wheel.  They go next to each other to provide both directions of spread. We have used part available, but I"m not sure you need the,.
 JimD
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 6:18pm
When you re assemble you need to make sure the wedge that fitts in the drive lugs can not have an eccentric on it or you will be picking the tractor back off the ground when it falls off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 6:40pm
Blake, you have a PM.  The eccentric wedge will not fit between the drive lugs.  It is wider than that.  Only the regular or plain wedge will fit in it.
ron nca View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ron nca Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 6:49pm
  Black try Tony Carbaugh I think he has them
