d-19 FUEL USEAGE AGAIN !
ACMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACMAN Quote  Post ReplyReply Direct Link To This Post Topic: d-19 FUEL USEAGE AGAIN !
    Posted: 25 May 2011 at 6:48pm
I have asked this before and checked the load screw to make sure it is in the jet since it is on a flex screw and it is. Here is the set up, was diesel, took our 230 out of scraped A-2 stuck in there. I am using combine carb had muffler shop make intake tube from carb to air cleaner, same I/D as carb, I don't know if the gas one is in the same location? Could the intake lenght be to long? I know some engines it makes a difference. I have new air filter/plugs/wires/points, D-19 gov assy. It will use (sit down now)5 to 6 gal per hr pulling a 214 disk high 2nd, power is not an issue, this works out to abou 1 gal per acre. Also even planting it still uses about the same this would be high 2nd @ 1/2 throttle or high 3rd @ 1/4 to 1/3. Is this about right? BTW my fuel man likes me!!!!! Thanks Bill.
junkman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 7:12pm
You sure you have a 230 and not a 262? I have the same setup in a D17, but it does not seam to be a gas hog. A friend of mine who is die hard Allis said he has made several this way and they were all good on fuel except for the wd 45 with a 262. Gas hog big time. Although you have to consider you are pulling taller tires to. My carb is a Marvel Shriber  which could make a difference as well.
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 7:15pm
D19 gassers had bit of a reputation as a gas hog but, wow! Have you ever put it on a plow?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACMAN Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 7:23pm
The tag says 230 I guess it is. As plowing goes I have a 4-16 snap-coupler semi-mounted will pull  it fine in high 2nd but the diesel would handle it better just couldn't keep the head on it.
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 8:03pm
a gallon per acre is what i burn with my 262 no matter what I am doing with the 19 lol
Teddy (punchie) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teddy (punchie) Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 9:37pm
Just used 5 gallons for plowing in a rough field. Started at 7:35 PM and stopped at 9:22 PM, just under 2 hours,  I average 2.5 - 3 gallons an hour. This was about 2 acres had allot of small trees, shrubs and weeds. Allot of unplugging,  some has not been plowed for years maybe never.  D19 gas 262 , no fuel pump was told it has a combine engine pulling 4-14 about 8 inches deep full throttle 2nd high.
Ac D-19, a Number of WD's, One WD45, Two 444 balers, Ac plows and etc.
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 7:09am
My Dad bought a new D19 gas in 1963. He would fill it up and go out to plow. He was nearly out of gas by noontime! It really used a lot of gas! Hated it.Traded it in for a new 190XTD as soon as they came out. Ran that one to 4000 hrs, no problems. Traded that on a 1970Ser III. The guy that bought that 1965 XT told me he ran it to 6800 hours without any problems or overhaul. D 19 Gas are fuel HOGS!
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 7:29am
I grew up on a WD45 that was a diesel and Dad put a rebuilt gas 262 with I believe the biggest venturi available in the carb. I don't remember it being bad on gas and I never heard Dad complain about it. something else about that engine is it was rebuilt 30 years ago and got heavy use for 10 years or so until Dad quit farming. Still runs great just like when it was new and uses no oil. I would think most engines would be about ready for an overhaul. We run it 2000 to 2200,2300 sings right along.
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 3:09pm
 My A2 Gleaner would burn a 40 gal tank in 8hrs shelling corn,which really don't load it that hard. There's yer 5 gal/hr
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 3:36pm
Every one thinks a D-19 gas uses a lot of gas ,try a 706 ,880 Oliver or some other brands of gas tractors and you may change  your might. First of all the gas today is not made for these tractors and also the D-19 only held 23 gallon of gas.
ALLISMAN32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALLISMAN32 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 10:00pm
Not sure about the exact fuel usage of the 262 in a d19, but as a youth discing with a gas 180 which displaces 265 cubes i never missed lunch or supper cause you had to go to the barn lot for gas every four hours or so!
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 10:51pm
Still haven't had to re-fuel the D19 diesel yet this year......
ALLIS EXPRESS!
This year:
