Wanted allis 180
genebue View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote genebue Quote  Post ReplyReply Direct Link To This Post Topic: Wanted allis 180
    Posted: 23 May 2011 at 7:57pm
gas, restored or in very good condition.  would consider diesel if the price was right.
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 11:29pm
There is a very nice 180 gas at Isaacson Implement in Nerstrand MN, not sure if it is close to your location or not.  It was just recently traded in and is very nice original.
Post Options Post Options   Thanks (0) Thanks(0)   Quote genebue Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2011 at 8:16am
I was there yesterday.  It's not as nice as the picture indicates, a lot of welding and leaking fluid and an early model not late as indicated.
ac45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2011 at 8:26am
 Have you ever owned a 180 gas??  Run a 180 diesel for 30 minutes and youd never go back, a diesel really shouldn't cost much more and with any use at all you will get the diference back in fuel savings.
Edited by ac45 - 24 May 2011 at 8:27am
Larry B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry B Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2011 at 9:56am
a gas is ok at least you don't have to worry about the antifreeze eating away the block. it just depends what you want to use it for.
nsula_country View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nsula_country Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2011 at 1:20pm
Anti-freeze in a diesel eating the block? Enlighten me.
CT
Post Options Post Options   Thanks (0) Thanks(0)   Quote genebue Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2011 at 4:59pm
I just had to completely rebuild the block in my 6080 because the antifreeze had eaten away around the sleeves and allowed the antifreeze to leak past the 0-rings into the oil.  John Deere has an additive to prevent this from happening.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nsula_country Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2011 at 6:09pm
I Googled this topic (diesel engine damage by improper antifreeze coolant) and found some interesting findings. I assume this is only on "wet sleeve" engines? Is the 2800 (301 cid) in the 180 a "wet sleeve" engine? I ask because I bought a 180D in February.
My understanding is the combustion process creates pressure spikes in the cylinder sleeve and the rapid flexing of the sleeve can cause a partial vacuum then pressuring of the void between the cylinder sleeve and block. During this process it can create air/water pockets that burst at pressures of up to 60,000 psi, this is what causes the pitting and erosion of the cylinder sleeves. Cold weather starts can further compound this issue because of the increased tolerances between parts until at operation temp.
Good news is it happens to on-the-road vehicles more than off-the-road vehicles and stationary power units because of the constant loads and engine speeds. I will check my coolant more often and also check the formulas I buy.
CT
wf32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wf32 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2011 at 7:51pm
genebue
Here is a 185 that my Dad has for sale he retired from farming
asking $5500 obo
located in SE MN
call 507- 482-6940
Phil
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2011 at 11:31pm
Two of my Uncles have 180 gas tractors and they are very nice tractors, good for winter and both have loaders.  One uncle also has a diesel as do I and both versions have their benefits.  Hope you can find one.  Seems to be a few on Tractorhouse.  The 180 gas tractors were only made in 1969.
Post Options Post Options   Thanks (0) Thanks(0)   Quote genebue Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 7:22am
It looks like a nice tractor. I am very interested and will give you a call.  I am located in the Melrose, WI area which is close to Brownsville.
Gary (sw Wis.) View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary (sw Wis.) Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 8:13am
Here one near Madison Wi. Not mine.
190XT - D17 - D14 - WD45 w/loader - WD - (2)B110 - 616H - 610 - B-208 - WD with 190 Mounted Corn Picker - All Crop 60
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry B Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 9:26am
As far as the antifreeze eating through all you have to do is put a water filter on it and that will take care of the problem, i know because over the years i rebuilt a 190,180, 7020 all because of this. Then when i bought a 7045 new we put the filter on it and run it over10000 hrs with no problem.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 9:36am
Where do you get these water filters?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 10:10am
Once the pitting has started the filter isn't as effective.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 11:40am
I was just reading an auction bill here and there is a 180 Gas on an upcoming auction.  The auction is consignment and located at Kenyon MN on June 4.  You can view the bill at www.maringauction.com  There were no pictures of it, but you may give them a call for details.
This page was generated in 0.143 seconds.
